29 30 31
juan luna, PestoJ30, Joe Knight, knothead, Robert Lama
1025 Registered Users
986,745 Dacron Main
165,480 Ananda's Refit
Topics3,987
Posts19,087
Members1,025
Re: Adjusting Throttle & Transmission Controls [Re: Rob Van Name] #19333
03/10/24 02:05 AM
03/10/24 02:05 AM
New Orleans, LA, USA
David Erwin Offline
David Erwin  Offline
Anyone know what would cause low horsepower when in reverse? Transmission in Forward mode is working well.
I have a Yanmar KM2A transmission,
Found this very nice film online.
https://forums.sailboatowners.com/t...n-basics-too.1249938030/#google_vignette
Any ideas are welcome.
Dave
Re: Adjusting Throttle & Transmission Controls [Re: Rob Van Name] #19334
03/10/24 08:25 AM
03/10/24 08:25 AM
Dave - it may be the clutch slipping due to glazed cone. See this old post and my old Rhapsody blog post. Hard to believe that was 14 years ago!
Re: Adjusting Throttle & Transmission Controls [Re: Rob Van Name] #19356
06/05/24 06:15 PM
06/05/24 06:15 PM
Belmont, MA
G
Georges Offline
Georges  Offline
G
Belmont, MA
When I had this issue with footloose:
  • I went through the same steps mentioned by Bill
  • I got this diagram from a mechanic - which really made me understand why you need to rev up initially when switching to reverse to get max torque over those diagonal groove which force the coupling - and then rev down to wherever you need...
  • I still ended up getting a new Martec (my prior one had already been refurbished too many time).
Both helped for 5-10 years or so... but to be fair I am a bit fed up by this inherent folding prop limitation.
I am considering switching to a feathering prop (e.g. https://www.pyiinc.com/max-prop-easy.html)... I saw in the forum that Ananda got one... and yes I read https://www.yachtingmonthly.com/gear/folding-and-feathering-propeller-test-29807 :-)
I would like to know if you really loose that significantly when racing... I still love speed...
KM2A-OUTPUT-SHAFT.jpg [86.44 KBytes] - (8 downloads)
-- Georges
0 registered members (), 19 guests, and 1 spider.
Raising the main; slugs get stuck
by Navy Dan. 07/17/24 06:50 PM
Main Sail Slugs
by juan luna. 07/09/24 07:34 PM
Sail slugs/slides on the mainsail
by juan luna. 07/09/24 06:15 PM
by Sunrise. 06/20/24 03:39 PM
by Georges. 06/05/24 06:15 PM
Replacement Shaft Strut / Galvanic Corrosion
by ivanjrod. 06/03/24 04:39 PM
Cut Engine Cover in Half
by Patrick Stinson. 05/28/24 10:56 PM
Need Spreader
by Eric Whan. 05/17/24 10:16 AM
by B Davis. 04/29/24 12:41 PM
