Paint color
#1967
02/08/08 07:51 PM
02/08/08 07:51 PM
Posts: 156 kailua, hawaii usa
mango madness
kailua, hawaii usa
I'm re-doing my boat (thanks to Rattle and Hum blog). I researched (googled) alot of pics of sailboats, I also checked everyones pic inthe registry database for j30's. I don't see anyone with dark color painted topsides. Before you start typing a response, I realize dark paint will radiate more heat than light colored paint. But i'm referring to the vertical areas of the topsides, and smooth edge areas. I still plan to have a lighter nonskid every where one would sit, walk or stand, but I think it looks bad when the tops sides are white(ish), and the hull is a bold color. an example is Screamin O'. This boat is bad. I will put forth the effort to keep a jet black gloss paint. But, I'm planning on painting the topsides jet black too. Please hit me with your thoughts. Thanks, mango http://dantowey.com/Photos/Sailing/LCYC%202006/ScreaminO/DSC_0768.jpg http://dantowey.com/Photos/Sailing/LCYC%202006/ScreaminO/DSC_0977.jpg
Re: Paint color
#1969
02/08/08 09:48 PM
02/08/08 09:48 PM
Posts: 493 Chicago, Il. USA
D. Bartley
Chicago, Il. USA
Screaming O... wow, so that's what happened to Pronto.
44
guests, and 14
