• Home
  • Class
    • Membership Application
    • Board of Governors
    • History
    • Contact Us!
  • Calendar
  • Fleets
    • Directory
    • Districts
    • Teams
  • Forum
  • Info
    • Official Specifications
    • PHRF Rating
    • J/30 @ J/Boats.com
    • Why Own a J/30?
    • J/30 Drawings and Files
    • Diesel Engine Maintenance
    • Articles of Interest
      • J/30 Rigging Information
      • J/30 Spreader Brackets
      • J/30 Rig Tuning
      • J/30 Crew Assignments
      • Cruising Your Racing J/30
      • J/30 Trailering
      • Building a Parking Sail
      • Barient Winch Information
      • Painting Your J/30
      • Shaft Log Replacement
  • Market
    • For Sale
    • Wanted
    • Equipment Suppliers
    • J/30 Apparel
    • J/30 Online Store
  • Photos
  • Regatta
2012 J/30
North Americans
October 18-21
New Orleans YC
New Orleans YC
2012 J/30 SNE
Regionals
July 21-22
Newport YC
Newport YC
2012 Cedar Point OD
June 2-3
Cedar Point YC
Cedar Point YC
Active Topics
Active Posts
Unanswered Posts
Advanced
You are not logged in. [Log In] J/30 Class Association » Forums » J/30 Forum » The Boat, Sails and Equipment » engine temperature problem
May
M Tu W Th F Sa Su
Bob Rude
595 Registered Users
j30news
(Views)Popular Topics
Dacron Main 97922
Northwest one-design 55235
J30.org Web Page 20724
Southern Straits 13273
Forum Stats
595 Members
27 Forums
2619 Topics
Topic Options
#2069 - 07/28/02 07:52 PM engine temperature problem
DRassiger Offline
Loc: Huntington Station, NY, USA
1981 Yanmar Diesel, hull #267. The engine temperature light/warning noise comes on regularly after about the first half hour of operation (strangely enough, it'll NEVER go on when motoring out, only when motoring back in). Raw water strainer is clean. New thermostat installed in spring of 2002 but problem has continued. Does this sound like an impeller problem or should I be looking elsewhere?
_________________________
Don R.
#267
Top
#2070 - 07/30/02 05:04 PM Re: engine temperature problem
Ed Austin Offline
Loc: New York, NY
Is there water spitting out the back? If there is none, check the water pump impeller. Also, I've had problems with my water strainer (Perko?) lid not sealing tighly and letting air into the system.
If there is very little or no water, check the fitting where the water goes into the exhaust elbow (a cast upside down U shaped pipe). The fitting I have bends 90 degrees and has clogged twice over the last 8 years. The first time I had to replace the exhaust elbow, the next time I managed to clean the fitting out with a stiff wire.
Ed Austin
Chinook
Top
#2071 - 07/31/02 10:08 AM Re: engine temperature problem
Try changing your oil and replacing it with a single weight marine oil. If your oil has failed the engine will not cool properly. Has your oil pressure changed? If the oil has broken down you pressure will be lower especially when the engine is hot. Good Luck.
Top
#2072 - 07/31/02 11:56 AM Re: engine temperature problem
Brad Stokes Offline
Loc: Corpus Christi, TX
Very common problem. The impeller is the first thing you'll want to check. The impeller may look perfect, but I've actually had one where the brass hub came unglued from the rubber impeller so the hub spun but the impeller didn't move. Be aware that the wear inside the water pump housing can reduce the pump's efficiency, so you may still have water spitting out the back but just not enough. Check to see that the walls inside the pump are not scored or worn. Inside the housing there is a small replaceable cam that compresses the impeller blades, if that is worn down you lose efficiency. Another big thing to check is the sea water strainer. If it is not air tight, it will leak air into the system. The old Perko strainer fastens with wing nuts on two sides, if you get it tightned down at an angle, it'll break vacuum and pull air. And check the gasket in the strainer cap. If its cracked, you'll lose the vacuum and pull in air. Finally, pull off some water hoses and make sure the water passages are not plugged with scale.
I replaced the sea water strainer and the water pump. Problem fixed.
Top
#2073 - 07/31/02 08:25 PM Re: engine temperature problem
dwl Offline
Loc: New York, NY, USA
If you do pull apart the water strainer, be prepared to replace it. Ours was fine until
we checked it (while sorting out a failed
engine seacock) and then basically all the various bits which are supposed to form a seal
stopped doing so. It was impressive. The gasket had clearly been compressed, but cracked, and once uncompressed, came apart. It went downhill from there. We quickly decided to simply replace it. 20 year old metallic bits which are in a salt environment can easily be dodgy.
- David
Top
#2074 - 08/16/02 04:59 PM Re: engine temperature problem
Bill Saltonstall Offline
Loc: Marion, MA USA
This summer I had a totally random series of times that the engine overheated - sometimes just after long hours of satisfactory operation. I had replaced the cam last year and the impeller several times, even though it did not appear to be defective. The mixing elbow is only two years old. I finally caught up with a very good Yanmar parts distributor at Orrs/Bailey Island in Casco Bay. He cautioned me that any scratch big enough to catch a fingernail in the pump housing or pump cover could create these failures. I removed the cover, which did have some scratches inside, polished up the outside and reinstalled it inside out. End of problem. It was clear that the pump started pushing more water out the exhaust, and the problem has never returned.
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  David Erwin
Print Topic
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
Who's Online
0 registered (), 7 Guests and 2 Spiders online.
X48 vs J30
Running the spin halyard
by Rhapsody #348
05/21/12 09:34 PM
by Cap'n Vic
05/21/12 08:54 AM
by Cap'n Vic
05/18/12 08:11 PM
Carbon Spinnaker Poles
by Cap'n Vic
05/18/12 08:05 PM
by JeffSmithNJphoto
05/18/12 07:22 AM
Grease Rudder Pintles?
by JeffSmithNJphoto
05/18/12 07:08 AM
by David Erwin
05/18/12 12:36 AM
by Cap'n Vic
05/17/12 08:21 PM
by Alan Veenstra
05/17/12 10:56 AM
Yanmar 2QM Engine Mounts
by CAN106
05/16/12 04:19 PM
Board Rules · Mark all read
