I have owned a J-30 for the past 20 years, and last year I had ice damge to the bottom as a result of water in the balsa core. I have bben advised that this may be a common problem resulting from an inadequate seal between the exhaust pipe and the hull. If anyone has had this type of damage I would appreciate knowing what was done to correct the problem. ThANKS IN ADVANCE.
