Re: Tiller pilot
#2442
08/19/03 10:39 AM
08/19/03 10:39 AM
I installed an Autohelm 4000. They say the mount should be 18" forward of the pintles. If I did it again, I'd be tempted to mount it further forward so the load on the motor would be less. The J30 with its unbalanced rudder loads up in a hurry. I might be tempted to call their tech support for their opinion.
Re: Tiller pilot
#2445
09/22/03 02:37 PM
09/22/03 02:37 PM
Posts: 127 Chicago, IL, US
rdpierce
Chicago, IL, US
I'm contemplating getting a RayMarine ST4000+ Is this the same as the Autohelm 4000? Should it be mounted higher up on the tiller? Is it strong enough, or should I shell out the $$$ for their Grand Prix version?
Ryan Pierce, #337 rdpierce@pobox.com
Ryan Pierce, #337
Re: Tiller pilot
#2449
06/17/04 11:43 AM
06/17/04 11:43 AM
Posts: 13 Pensacola, FL, USA
Tom Eskridge
Pensacola, FL, USA
I installed a tp30 on my 1984, and put it at the recommended distance from the pintles. I needed a 1" push rod extension, and the big tiller bracket. It does get loaded up fast, so moving it a few inches further out might be a good idea.
Tom Eskridge Twister #469
guests, and 1
spider. |
