Re: Need new shifting mechanism for J-30
#2564
06/05/01 09:57 PM
06/05/01 09:57 PM
Posts: 124 New York, NY, USA
dwl
New York, NY, USA
Before you go off and replace the shifter, I'd check a couple of things. Are shift cables moving freely? A kink in a cable, or a worn cable can make the shifter bind. Likewise, check the linkages at both ends of the cables for nice clean, firm attachments. All kinds of funny binding can happen when these guys get out of adjustment. It's also worth popping your head into the back end of the engine and make sure that the transmission itself isn't the culprit. You can work the shift lever by hand, and it should move fairly easily. While you're at it, if you haven't checked fluid levels back there, of course, you should.
Lastly, I'd spend some energy just soaking all the bits of the shifter in WD-40, followed by a proper lubricant (We all know WD-40 isn't a lubricant, don't we :-) It took several passes to get our shifter (hull 3) fully sorted out, but it's been fine since then.
- David Levine
[This message has been edited by dwl (edited 06-05-2001).]
#2565
06/06/01 08:45 PM
06/06/01 08:45 PM
Minney's Ship Chandlery 1500 Old Newport Blvd. Costa Mesa, CA 92627 tel #(949) 548-4192 has used surplus. I got one last year and they had a lot more. good luck!
#2567
07/12/01 11:35 AM
07/12/01 11:35 AM
I replaced it with a Morse two lever using the same hole and cables. It is very handy to set the idle to 850 RPM and use the transmission lever to control the boat for docking and approach. They are pricey though.
44
guests, and 14
