• Home
  • Class
    • Membership Application
    • Board of Governors
    • History
    • Contact Us!
  • Calendar
  • Fleets
    • Directory
    • Districts
    • Teams
  • Forum
  • Info
    • Official Specifications
    • PHRF Rating
    • J/30 @ J/Boats.com
    • Why Own a J/30?
    • J/30 Drawings and Files
    • Diesel Engine Maintenance
    • Articles of Interest
      • J/30 Rigging Information
      • J/30 Spreader Brackets
      • J/30 Rig Tuning
      • J/30 Crew Assignments
      • Cruising Your Racing J/30
      • J/30 Trailering
      • Building a Parking Sail
      • Barient Winch Information
      • Painting Your J/30
      • Shaft Log Replacement
  • Market
    • For Sale
    • Wanted
    • Equipment Suppliers
    • J/30 Apparel
    • J/30 Online Store
  • Photos
  • Regatta
2012 J/30
North Americans
October 18-21
New Orleans YC
New Orleans YC
2012 J/30 SNE
Regionals
July 21-22
Newport YC
Newport YC
2012 Cedar Point OD
June 2-3
Cedar Point YC
Cedar Point YC
Active Topics
Active Posts
Unanswered Posts
Advanced
You are not logged in. [Log In] J/30 Class Association » Forums » J/30 Forum » The Boat, Sails and Equipment » Replacing Propeller Shaft 7/8 vs 1 Inch
May
M Tu W Th F Sa Su
Bob Rude
595 Registered Users
j30news
(Views)Popular Topics
Dacron Main 97922
Northwest one-design 55235
J30.org Web Page 20724
Southern Straits 13273
Forum Stats
595 Members
27 Forums
2619 Topics
Page 1 of 2 1 2 >
Topic Options
#2568 - 10/22/07 09:26 PM Replacing Propeller Shaft 7/8 vs 1 Inch
David Erwin Offline
Class Co-President
Loc: New Orleans, LA, USA
Hey, while my J/30 is out of the water, I am considering upgrading the shaft. I think the current diamater is 3/4 inch. After reading the posts, I have noted some references to 7/8 inch and some to 1 inch upgrades.
For those with an upgraded to 1 inch, did you change out the strut?
Did you ask a local machine shop to produce the new shaft?
Any tips are appreciated.
Dave@j30.us
Top
#2569 - 10/22/07 10:00 PM Re: Replacing Propeller Shaft 7/8 vs 1 Inch
Rhapsody #348 Online   content
Class Co-President
Loc: Portsmouth, RI
David - Rhapsody has a 1" shaft. I met the original owner this summer and he indicated the boat (Hull #348 originally named Tontine in 1981) was built with a 3/4" shaft, but he had heard of other owners complaining of "shaft whip" vibration, so he convinced Everett Pearson to change the shaft. He said that the day before he took delivery that TPI cut out the old strut, and glassed in a new one. This explains why I have a 9" square seam line above the strut inside.
So, it is major work to upgrade to a 1" shaft. I'd try 3/4" for now and see if you have a vibration problem. If not, you're set. If so, consider this the 1st item on the list next time you haul the boat. Just remember you'll need a new shaft seal and coupling flange too. It's only money....
Bill
_________________________
Bill Kneller
Rhapsody J/30 #348
Projects & Documentation
Top
#2570 - 10/23/07 11:24 AM Re: Replacing Propeller Shaft 7/8 vs 1 Inch
D. Bartley Offline
Loc: Chicago, Il. USA
Would you not also need a new prop? That could also be a bit expensive.
Dennis Bartley
Planxty, s/n 23994
hull 205
Top
#2571 - 10/23/07 11:33 AM Re: Replacing Propeller Shaft 7/8 vs 1 Inch
Rambunctious Offline
I am almost certain the shaft in my boat is 3/4". It definitely isn't 1". I don't buy that the larger shaft is necessary to reduce vibration. I'm sure it would be a nominal improvement, but I would first look issues like the cutless bearing, shaft alignment and motor mounts before I began to even consider beefing up the shaft. If there is enough abnormal vibration to cause you to wonder, I would bet that the cause is one of those symptoms rather than an undersized shaft.
If it aint broke, don't fix it, right?
(Or, on my boat, if it aint broke, don't use it.)
- Jason
Rambunctious #280
Top
#2572 - 10/23/07 11:39 AM Re: Replacing Propeller Shaft 7/8 vs 1 Inch
Class Co-President
Loc: Portsmouth, RI
Quote:
Oops - the most expensive part I missed. Dennis is correct. I'm sure the strut isn't cheap either.
Bill Kneller
Rhapsody J/30 #348
Top
#2573 - 10/23/07 12:30 PM Re: Replacing Propeller Shaft 7/8 vs 1 Inch
David Erwin Offline
Class Co-President
When changing out the stuffing box this weekend, we discovered that the shaft is not exactly the same size as the coupler. Keep in mind that I have never used the engine as this boat is new to me, so I do not know if there was any existing vibration. The part of the shaft where it connects to the coupler is black indicating that area was heated. I am hoping that the actual problem with vibration was related to a mismatch in size vs. shaft size. Perhaps the problem was misdiagnosed in the past? I am getting the shaft and coupler measured with a micrometer today to see where we go. While the boat is out of the water, this of course is the perfect time to address issues like this. :> ) I sent the Ecliptec prop to Martec today to be rebuilt.
We're painting the mast and boom. Baltoplate will be applied when it stops raining.
We haven't painted the area around the Windows. Can't make up our mind about to paint white like the hull or Zephyr blue.
There is a light at the end of this tunnel.
Top
#2574 - 10/23/07 09:00 PM Re: Replacing Propeller Shaft 7/8 vs 1 Inch
D. Bartley Offline
A new coupler for 3/4" shaft is about $110 (or thereabouts).
Dennis Bartley
Planxty, s/n 23994
hull 205
Top
#2575 - 10/26/07 09:23 AM Re: Replacing Propeller Shaft 7/8 vs 1 Inch
dbows Offline
Loc: Marblehead, MA
Dave - if it is a 2GM not a 2GM20 then you are wasting your money on a bigger shaft. The larger shaft was due to the added horsepower of the 2GM20 on the new boats. The shaft is so short that vibration is coming from other things like shaft mis-alignment, shaft ware at the stuffing box and strut, bad motor mounts, prop needs reconditioning and/or new cutless bearing. My boat has NO vibration underway and it has a new 3/4 shaft that was professionally aligned, new dripless seal, reconditoned prop and new cutless bearing. However this all was a small fortune.
David
#397
Top
#2576 - 10/26/07 09:25 AM Re: Replacing Propeller Shaft 7/8 vs 1 Inch
dbows Offline
Loc: Marblehead, MA
Dave - FYI
While you are at it, remove the sound proofing on the engine cover/steps and paint with Silent Running paint. I removed about 30lbs of lead from the sound proofing and made a huge improvment in sound dampening down below.
David
#397
Top
#2577 - 10/26/07 01:03 PM Re: Replacing Propeller Shaft 7/8 vs 1 Inch
David Erwin Offline
Class Co-President
David,
Thanks for the clarification. Can you direct me toward a part number or source of the dripless stuffing box?
Top
#2578 - 10/26/07 01:45 PM Re: Replacing Propeller Shaft 7/8 vs 1 Inch
Class Co-President
Loc: Portsmouth, RI
David - I think David Bows used the same brand I have - PYI Inc. Dripless Shaft Seal - look at this link: http://www.pyiinc.com/
You can get the part number for your application by entering the shaft diameter and stern tube outside diameter. Once I got the part number, I found the best price from Go2Marine.com - you may want to do an updated price search.
Bill Kneller
Rhapsody J/30 #348
Top
#2579 - 10/26/07 02:11 PM Re: Replacing Propeller Shaft 7/8 vs 1 Inch
dbows Offline
Loc: Marblehead, MA
David - I will try to get the exact part number. There are two dimensions - the shaft size and the shaft log tube diameter.
DB
#397
Top
#2580 - 10/30/07 06:42 PM Re: Replacing Propeller Shaft 7/8 vs 1 Inch
Bob Rutsch Offline
Loc: Maryland, USA
Quote:
Originally posted by dbows:
paint with Silent Running paint I removed about 30lbs of lead from the sound proofing and made a huge improvment in sound dampening down below.
David
#397
Ignoring whether this is removing original equipment, my lead has been duct taped so many times it is a complete mess. Looking at their web page, this sounds like a much better answer.
Top
Page 1 of 2 1 2 >
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  David Erwin
Print Topic
View profile
Send a PM
View homepage
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
Who's Online
0 registered (), 7 Guests and 2 Spiders online.
X48 vs J30
Running the spin halyard
by Rhapsody #348
05/21/12 09:34 PM
by Cap'n Vic
05/21/12 08:54 AM
by Cap'n Vic
05/18/12 08:11 PM
Carbon Spinnaker Poles
by Cap'n Vic
05/18/12 08:05 PM
by JeffSmithNJphoto
05/18/12 07:22 AM
Grease Rudder Pintles?
by JeffSmithNJphoto
05/18/12 07:08 AM
by David Erwin
05/18/12 12:36 AM
by Cap'n Vic
05/17/12 08:21 PM
by Alan Veenstra
05/17/12 10:56 AM
Yanmar 2QM Engine Mounts
by CAN106
05/16/12 04:19 PM
Board Rules · Mark all read
