Re: spinnaker rigging
#2614
05/09/06 02:02 AM
05/09/06 02:02 AM
Posts: 124 New York, NY, USA
dwl
New York, NY, USA
Twings, from the obvious stanchion, for us. We have a nice harken ratchet with a camcleat on the block, and we lead straight out at max beam, tail to the rail.
We don't fly lightairs, just have stripped tails for our sheets, so the weight penalty is pretty tiny. (Some original boats had seperate sheets/guys, that's total overkill with modern lines)
Some boats hatch launch off the forehatch. (Gotta have a clean, modern hatch, or be a sailmaker, to make the work) Some people bag launch. We bag launch from the middle of the leeward rail, although if we replace our forehatch, one of these days, I think we'll seriously look at that.
- David
#2616
05/09/06 10:49 AM
05/09/06 10:49 AM
Posts: 493 Chicago, Il. USA
D. Bartley
Chicago, Il. USA
Spinnaker halyard on cleat at mast. I believe you can find a bracket at Layline to mount the cleat.
Foreguy is double ended so that adjusting the guy is easy on either side of the boat.
We also launch the chute from a bag in the companionway. North's rectangular spinnaker bags happen to be a perfect size for that. We almost always douse the chute on the port side.
#2617
05/10/06 02:22 PM
05/10/06 02:22 PM
Posts: 159 grand rapids, mi
311 Temptation
grand rapids, mi
we have our twing lines run thru a medium bullet block mounted on a stanchion base (on the wire support); the spinn sheet runs thru another medium bullet block, which is tied to that end of the twing line. The Twing line runs thru the stanchion block to a fairlead mounted between the windows on the cabin top sides, then aft to a standard harken camcleat. Works great, must have twings. To rig it, we first rig the twings, then we run the sheets.
The spinn launches great from the companionway launching bag. I wish I'd first seen the Chicago boat's method of hanging the bag from light line running fore & aft along the cabin roof. Mine is mounted to 4 pad eyes, one per corner. My bag stays put. Their bag slides all the way forward to the fwd bulkhead, out of the way so when you want to use the companionway, you just shove the bag forward. That is a nice tweak. Figure out the simplest method of doing anything and begin there.
#2619
05/13/06 12:22 AM
05/13/06 12:22 AM
Posts: 5 wichita, ks, usa
Tom Olsen
wichita, ks, usa
Do you have a digital photo of how you run this back to the cockpit that you could send on an e-mail?
GrandLakeJ30
#2620
05/13/06 12:23 AM
05/13/06 12:23 AM
Tom Olsen
wichita, ks, usa
I ment to ask Tempty 311 if they had a digital photo of the set up.
GrandLakeJ30
47
guests, and 14
