I am about to install a sailcomp compass on the mast and need to run the cable into the cabin to connect to the rest of the gear. Does anyone have any slick ideas on the best installation for running the cable through the deck/mast?
Bob Rude
Re: Sailcomp Cable#2982 03/28/0010:25 AM03/28/0010:25 AM
For the instrument on my mast, I ran the cable down the main sail track thru the partners. When it reaches the bottom of the mast, it comes out of the track and follows the other mast wires under the head.
