Re: backstay set-up
#2999
05/13/08 08:32 AM
05/13/08 08:32 AM
Posts: 493 Chicago, Il. USA
D. Bartley
Chicago, Il. USA
David, That was good
Re: backstay set-up
#3004
05/13/08 06:27 PM
05/13/08 06:27 PM
Posts: 649 Marblehead, MA
dbows
Marblehead, MA
The first drawing is almost the same as what I have except I have two fairleads on each side of engine control panel - as far out to the edges as possible (vs on top). This keeps the line as far back, and as wide as possible at the tiller.
David #397
[This message has been edited by dbows (edited 05-13-2008).]
44
guests, and 14
