February
Brooks Ritchey, vcyachting, Badfish2, neumannaudio, Kenpickard
930 Registered Users
868,294 Dacron Main
133,240 Ananda's Refit
Topics3,776
Posts18,429
Members931
Most Online223
Dec 17th, 2019
Repair of boom slot #3049
05/29/08 11:09 AM
05/29/08 11:09 AM
Detroit, MI
RobC222 Offline OP
RobC222  Offline OP
Detroit, MI
Last night, the clew slug in the boom blew out through the slot, yielding the aluminum at the slot, making it useless for retaining the slug.Luckily I had a safety strap around the boom and clew ring.
Has this happened to anyone else, and do you have a quick and dirty fix (i.e., short of replacing the boom)?
Re: Repair of boom slot #3050
05/29/08 11:27 AM
05/29/08 11:27 AM
Rhapsody #348 Online content
Rhapsody #348  Online Content
One of my old mains doesn't even have a slug. There is a velcro band that goes 3 times around the boom through the clew of main. Outhaul still attaches to the clew. A sail tie would probably do the trick too.
Re: Repair of boom slot #3051
05/29/08 11:54 AM
05/29/08 11:54 AM
New Orleans, LA
Rambunctious Offline
New Orleans, LA
I have stainless steel plates screwed onto the boom that prevent this. The same thing that happened to you happened to another boat in this area and installing these plates prevented it recurring. I can find out where he ordered it, if you would like; I believe it was RigRite or Rigging Only.
The photo below (the best I could find, this is the boat when I bought it) shows the plates at the end of the boom.
[This message has been edited by Jason King (edited 05-29-2008).]
Re: Repair of boom slot #3052
05/30/08 07:39 AM
05/30/08 07:39 AM
Rochester, MN
Scott Offline
Scott  Offline
Rochester, MN
I had that happen on my old boom as well. I used a velcro strap, as stated above. I use that now on my new boom as well, just to ensure that doesn't happen again.
Re: Repair of boom slot #3053
05/30/08 10:21 AM
05/30/08 10:21 AM
Detroit, MI
RobC222 Offline OP
RobC222  Offline OP
Detroit, MI
Scott,
You use the strap alone, or in combo with a slug?
Re: Repair of boom slot #3054
05/30/08 11:38 AM
05/30/08 11:38 AM
Chicago, Il. USA
D. Bartley Offline
D. Bartley  Offline
Chicago, Il. USA
On Planxty (hull #205), we use the strap alone.
Dennis Bartley
Planxty, s/n 23994
hull 205
Re: Repair of boom slot #3055
05/30/08 03:51 PM
05/30/08 03:51 PM
Rochester, MN
Scott Offline
Scott  Offline
Rochester, MN
The strap alone. It's worked great for years now.
Re: Repair of boom slot #3056
07/10/08 09:40 AM
07/10/08 09:40 AM
Toronto, ON
E
Eric Whan Offline
Eric Whan  Offline
E
Toronto, ON
I have the stainless cheek plates as well, but they did not prevent my clew slug from blowing out of the track and parting the outhaul last night. The wind was in the low end of the #3 range, so the main was fully loaded.
Upon inspection back at the dock, it became apparent that a previous owner had moved the cheeks down away from the slot by about 2mm. The lateral force on the main caused the windward edge of the slug to pry out of the slot, distorting the aluminum.
So, be sure the cheeks are mounted flush with the slot AND use a tie-down strap for redundancy. Hindsight...
0 registered members (), 37 guests, and 0 spiders.
First cruise
Freeze question
by Rhapsody #348. 02/25/21 12:44 PM
J-30 sails and parts
by Bob Rutsch. 02/24/21 04:54 PM
What's Inside the Boom
by --Ajax--. 02/24/21 08:22 AM
Looking for J30 main
by the redhead. 02/23/21 01:48 AM
#1 and #2 jib
by the redhead. 02/23/21 01:36 AM
Origo alcohol stove 4100
by the redhead. 02/23/21 01:33 AM
In Need Of J-30 Spinnaker
by j30sailor. 02/20/21 02:20 PM
by Koesh. 02/13/21 01:59 PM
Sails: Main, Unknown, #2, #3, Spinnaker in CA
by watchoverya. 02/13/21 01:52 PM
Deck core
by Phil Spletter. 02/11/21 10:00 PM
