J30 parts for sale
#3071
03/20/02 09:08 AM
03/20/02 09:08 AM
Anyone interested in parts? We are currently parting out a J30. Everything is still available except the hull and bow pulpit. Contact brian@torresen.com if interested.
Re: J30 parts for sale
#3073
03/20/02 06:04 PM
03/20/02 06:04 PM
It is hull number #83. The boat was a victim of the transom exhaust problem these boats are famous for. I strongly suggest all J-30 owners check the aft port quarter for moisture and repair any problems found.
#3074
03/20/02 09:41 PM
03/20/02 09:41 PM
Excuse me, make that the starboard aft quarter.
#3079
03/21/02 12:15 PM
03/21/02 12:15 PM
Posts: 104 Lake Stevens, WA, USA
Alan Grim
On hull #359, I discovered through an accident the makeup of the transom. While out sailing in heavy air (35 kts with gusts to 50) and putting a reef in the main, we didnt see a log until we were on top of it. The log stopped the boat as it went under the keel. As we surged over the log with the keel, the log rose up and struck the lowest point on the rudder. I heard a distinct crunching noise. One of my crew looked over the stern and saw that the lower gudgeon bracket had bowed outward approx 5/8". We didnt see any other stern damage at the time. Plus, with the reef in, the helm was well balanced and unloaded. So we finished the race and returned to the slip. Thats when I discovered the tear in the stern fiberglass around the upper gudgeon bracket. On hull #359, there is a core about 6" wide running from the top of the stern panel to the bottom apparently to stiffen the panel at the gudgeon supports. The rest of the panel is solid glass. No evidence of coring. There was no coring at the rip in the glass and the panel remained the same thickness from side to side and top to bottom.
This doesnt tell me that the stern panel was made separate from the hull halves but it does tell me that a leak at the exhaust should not damage the core. Its in solid glass.
In any case, insurance and a good shop repaired my stern to my satisfaction, except of course for the increase in premiums.
#3080
03/21/02 02:06 PM
03/21/02 02:06 PM
Posts: 173 Arnold, MD
Joe Ruzzi
Arnold, MD
Alan, I don't understand this part ... On hull #359, there is a core about 6" wide running from the top of the stern panel to the bottom apparently to stiffen the panel at the gudgeon supports. Do you mean there is a _balsa_ core running vertically ... or is there some additional fiberglass? If the entire hull is built in two vertical halves, then this might have just been some tabbing to reinforce the joint.
44
guests, and 14
