Re: Headsail Alternatives
#3185
06/05/03 12:46 PM
06/05/03 12:46 PM
I just installed a new Harken Unit 0 split drum furling system. Yes, the hardware was not cheap (about $1500) and I cut down an old 163% mylar genoa to about 140% and had a sunshade sewn on for about $200. It is worth the investment and the drop in performance is not an issue as the split drum design makes taking it apart and hauling up my newer 163% a snap.
#3186
06/11/03 02:32 PM
06/11/03 02:32 PM
We have a harken rollerfurling unit and the 163% genoa and have not taken that much of a speed hit. We still pretty much hit and exceed the polars without a problem. It is also much easier to use. If you are double handed or single handed racing the norm is to have roller furling for the obvious advantages.
In terms of Code 0 we got one for the express 37 I race on. It was a lot of $$, and the A-kites are better for a wider wind range and better angles. When you are in range to use a Code 0, however (which is a pretty narrow degree range for sailing) the boat takes off and you can completely wax all other competitors.
48
guests, and 0
