• Home
  • Class
    • Membership Application
    • Board of Governors
    • History
    • Contact Us!
  • Calendar
  • Fleets
    • Directory
    • Districts
    • Teams
  • Forum
  • Info
    • Official Specifications
    • PHRF Rating
    • J/30 @ J/Boats.com
    • Why Own a J/30?
    • J/30 Drawings and Files
    • Diesel Engine Maintenance
    • Articles of Interest
      • J/30 Rigging Information
      • J/30 Spreader Brackets
      • J/30 Rig Tuning
      • J/30 Crew Assignments
      • Cruising Your Racing J/30
      • J/30 Trailering
      • Building a Parking Sail
      • Barient Winch Information
      • Painting Your J/30
      • Shaft Log Replacement
  • Market
    • For Sale
    • Wanted
    • Equipment Suppliers
    • J/30 Apparel
    • J/30 Online Store
  • Photos
  • Regatta
2012 J/30
North Americans
October 18-21
New Orleans YC
New Orleans YC
2012 J/30 SNE
Regionals
July 21-22
Newport YC
Newport YC
2012 Cedar Point OD
June 2-3
Cedar Point YC
Cedar Point YC
Active Topics
Active Posts
Unanswered Posts
Advanced
You are not logged in. [Log In] J/30 Class Association » Forums » J/30 Forum » The Boat, Sails and Equipment » Re-sealing Cabin Windows
May
M Tu W Th F Sa Su
Bob Rude
595 Registered Users
j30news
(Views)Popular Topics
Dacron Main 97922
Northwest one-design 55235
J30.org Web Page 20724
Southern Straits 13273
Forum Stats
595 Members
27 Forums
2619 Topics
Topic Options
#3219 - 04/18/02 03:30 PM Re-sealing Cabin Windows
I have hadd my J/30 for 4 years now and have basically sealed the windows each year with a little silicon. does the job but thought I might how I could do this more permanently and with a little better visual appeal.
Top
#3220 - 04/18/02 04:25 PM Re: Re-sealing Cabin Windows
Joe Ruzzi Offline
Loc: Arnold, MD
You may want to consider taking the plastic portlights out completely and then re-bedding them in a different caulk. The last time I did this, I used a polysulphide/silicone blend. It worked ok, but it tends to attract dirt. So, I'm also looking for a better suggestion.
Top
#3221 - 04/19/02 04:44 PM Re: Re-sealing Cabin Windows
I re-sealed mine several years ago using Life Seal. It worked great. No problems and no leaks.
Top
#3222 - 04/21/02 03:07 PM Re: Re-sealing Cabin Windows
Bobby Cox Offline
Loc: Oxford, MI
I remade and replaced my portlights about 4 years ago and used Life Seal as well. It is a combination of polyurethane/silicone and has not leaked yet. DO NOT USE POLYSULFIDE on the portlights because it will attack the portlight material and result in problematic leaks until they are replaced (experience speaking!) B. Cox
Top
#3223 - 04/26/02 02:07 PM Re: Re-sealing Cabin Windows
We made new portlights out of Bronze coloured plexi 3 years ago still not leaking.
1) Windows were fabricate 1/4 smaller than the opening flange.
2) Butyl tape was placed on fiberglass cabinhouse flange.
3) Windows were placed in.Mask around windows and gelcoat.
4) Fill space with high guality window installer silicone.
Products were purchased from a automotive window installer.
Plexi was purchased from a company call Cadillac Plastics.
Top
#3224 - 05/09/02 08:15 PM Re: Re-sealing Cabin Windows
Replaced my windows with new lexan about 7 years ago. Used GE Silcone II. Found that most good silcones will work. The secret to any good seal is to sand the two surfaces no matter if it is plastic, fiberglass, or metal. Use GoJo or another hand cleaner to clean up the excess silcone before it hardens.
Had a winch that I installed with silcone II and I needed to remove after about 4 years and I had to pry it off with putty knives and chisels. Could have used the winch without the bolts in it.
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  David Erwin
Print Topic
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View posts
Who's Online
0 registered (), 10 Guests and 3 Spiders online.
X48 vs J30
Running the spin halyard
by Rhapsody #348
05/21/12 09:34 PM
by Cap'n Vic
05/21/12 08:54 AM
by Cap'n Vic
05/18/12 08:11 PM
Carbon Spinnaker Poles
by Cap'n Vic
05/18/12 08:05 PM
by JeffSmithNJphoto
05/18/12 07:22 AM
Grease Rudder Pintles?
by JeffSmithNJphoto
05/18/12 07:08 AM
by David Erwin
05/18/12 12:36 AM
by Cap'n Vic
05/17/12 08:21 PM
by Alan Veenstra
05/17/12 10:56 AM
Yanmar 2QM Engine Mounts
by CAN106
05/16/12 04:19 PM
Board Rules · Mark all read
