DIESEL PROBLEMS
#3276
07/19/00 07:13 PM
07/19/00 07:13 PM
HELP!!!!! WE ARE HAVING WITH FUEL STARVATION ON AN INTERMITTENT BASIS. BLEEDING THE FUEL LINE IMMEDIATELY RESTORES THE ENGINE TO RUNNING STATUS. HAVE CHCKED AND RECHECKED THE FUEL PICK UP, VENT LINES, FUEL LINES ETC. EACH TIME THIS HAPPENS THE FUEL FILTER IS EMPTY. ANY AND ALL SUGGESTIONS WILL BE WELCOMED!
Re: DIESEL PROBLEMS
#3280
08/07/00 09:18 AM
08/07/00 09:18 AM
Does anyone know the normal operating oil pressure for a Yanmar 15. I find that my engine runs for the first hour at about 38psi; after about an hour it drops down to 21psi and stays there. Is this a problem? I had to motor for three hours this past weekend and it was stressing me out. Help!
44
guests, and 14
