March
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
1017 Registered Users
976,225 Dacron Main
162,648 Ananda's Refit
head sail luff and leach measurements #3602
06/12/05 11:24 PM
06/12/05 11:24 PM
kansas city, mo
J
jezabelle Offline OP
J
kansas city, mo
Does anyone know the correct measurments for a roller furling163% and 155% leach and luff? Is 155 the current PHRF choice or is it 150%? DOes the class or Phrf regulate how much of the sail gets removed to roll properly or do they only care about maximum dimension?
thanks,
clint
Re: head sail luff and leach measurements #3603
06/13/05 09:28 AM
06/13/05 09:28 AM
Olney, IL
Thor Offline
Thor  Offline
Olney, IL
Phrf only cares about max size ( i.e. 155 )
I just send my 155 to North and they knew the dimesions to cut away for the harken furler... ( different furlers different dimensions )
Thor
Thor
Cabin Table Wanted
by B Davis. 01/20/24 11:03 PM
Fuel Fill O Ring
