Rudder
#3612
01/03/02 05:12 PM
01/03/02 05:12 PM
anyone know what a J30 rudder should weigh? Mine is 1000 pounds for some reason. thanks
Re: Rudder
#3614
01/04/02 02:42 PM
01/04/02 02:42 PM
Posts: 493 Chicago, Il. USA
D. Bartley
Chicago, Il. USA
Well, 1000 lbs. is a bit excessive. I happen to have mine in the basement, so I just went down and weighed it with a reasonably accurate digital scale. Several weighings all produced 72 lbs. That included hardware with pintles. No modification to the rudder has ever been done.
Re: Rudder
#3615
01/04/02 05:08 PM
01/04/02 05:08 PM
Dennis, you indicated that the hardware was attached to the rudder (pintles). What about the stainless-steel tiller bracket?
Re: Rudder
#3616
01/04/02 06:24 PM
01/04/02 06:24 PM
BTW - just weighed my rudder and got 71 lbs. The rudder had only the pintles attached. The tiller bracket was off. The bolt/axel for the tiller bracket was also removed.
Re: Rudder
#3617
01/05/02 12:38 AM
01/05/02 12:38 AM
D. Bartley
Chicago, Il. USA
Yes Mike. Both tiller and it's SS bracket removed.
1000 lbs seems rather excessive... I wonder if it's possible for it to soak up that much water. Wonder if "ppasko" meant 100?
Re: Rudder
#3618
01/05/02 01:06 AM
01/05/02 01:06 AM
It would be good to get data from one more original rudder. If anyone else has stored their rudder at home for the off-season, please weigh it and share your results...
How Much does your Rudder Weigh?
#8924
02/07/10 01:25 PM
02/07/10 01:25 PM
Posts: 2,669 Portsmouth, RI
Rhapsody #348
I thought this would be interesting for people to collect the data and see what we find. I used a very sophisticated method. I got out the bathroom scale and weighed myself, then held the old rudder that was damaged and repaired, recorded that weight and subtracted my weight. I then did the same with the new IdaSailor rudder I bought to replace the damaged rudder after my Block Island storm damage. Note the damaged rudder is usable since the repairs were done, just a little heavy. These weights are just the rudder, no mounting hardware. 73 Pounds - Original Repaired Rudder (horizontal in picture) 60 pounds - IdaSailor Rudder (upright in picture) Post your rudder weights here if you have measured it. Class spec per para 5.6.1 is 60 pounds minimum. I doubt many people find a rudder below that weight...
44
guests, and 14
