my boat stinks
#3687
06/26/05 11:51 PM
06/26/05 11:51 PM
Posts: 164 Olney, IL
Thor
Olney, IL
:-) any ideas ? My boat stinks in the v berth, seems to come from the front behing the hatch .... prior owner wrapped saran wrap around the hose from the tank , which is most likely not working ...
replace the vent tube ? what tubing should I get ??? dont live near a west marine or any boat shop ?
Should I replace some other tubing as well ? or just start with the vent tube ?
Thor
Thor
Re: my boat stinks
#3688
06/27/05 02:10 AM
06/27/05 02:10 AM
Posts: 61 Anchorage, AK, USA
SCampbell
Anchorage, AK, USA
It sounds to me like your hoses have finally given up the ghost. I replaced all the hoses from the head to the thru hull with hose from West Marine. I don't remember what it was, but it was a solid white hose instead of what looked like vacuum cleaner hose that was on the boat when I bought it. I have yet to replace the hose coming from the holding tank to the pumpout fitting since I haven't been able to make the sharp bend as was done originally. My latest thought is to try and find some sort of J-tube made from hard plastic and splice it in where the the hose makes the u-turm coming out from the aft, bottom of the holding tank. So far, I haven't been motivated enough to try and hunt one down though. Also, you will probably find that the hose from the head to the vacuum breaker, to the Y valve will all be the same size. The thru hull nipple is about 1/8 inch larger diameter. I ended up heating the hose in boiling water to soften it up enough to get it over the hose barb. By far the hardest part of the job. The manufacturer of the hose does not recommend heating it to make it fit, but I haven't had a problem in the three years since I have done the replacement. Good luck! Changing the hoses should do the trick. (You won't believe the crap you will find in them either!)
Re: my boat stinks
#3690
06/27/05 11:34 AM
06/27/05 11:34 AM
Posts: 649 Marblehead, MA
dbows
Marblehead, MA
A good solution to get the hose to go around corners is a hair dryer. Just heat the hose a bit and it will go just about anywhere (-:
David
Re: my boat stinks
#3691
07/05/05 02:39 PM
07/05/05 02:39 PM
Thor
Olney, IL
thanks for the replies i looked at it and yes I will change all the hoses ... just not yet in the summers heat.... what I did is to transfer my solar vent from the coach roof to the inspection hole in front .... just droped it in and now the smell, which used to accumulate in the front triangle is pulled out , before it meanders into the v berth .. so far so good ...
new hoses in the winter ...lol
thor
Thor
Re: my boat stinks
#3695
05/29/07 03:37 PM
05/29/07 03:37 PM
Posts: 190 Atlanta, GA, USA
whitedolphin
Atlanta, GA, USA
Thanks for the advice, looks like I've got a pretty nasty job cut out for me! I just bought the boat so the, um, waste isnt even my own The boat is in Charleston which probably doesnt have any days cold enough to freeze up the holding tank - so I guess it will be a respirator and some long gloves! The hoses seem to be the thick black rubber kind and who knows how old they are. It looks like the white stuff at West Marine is the way to go and I may try dropping a fan in the front inspection hole in the mean time. Thanks for the info! -dan
Re: my boat stinks
#3696
05/29/07 05:58 PM
05/29/07 05:58 PM
dbows
Marblehead, MA
The best way to check if you hoses are permiating the smell is to take a dish towel and soak it in really hot water and then spread it around a section of the pipe and let it sit for a few minutes. Then remove the towel and smell it. It the towel smells, the hoses need to be replaced.
David #397
41
guests, and 14
