Re: runnng rigging
#3740
10/24/03 08:31 AM
10/24/03 08:31 AM
Posts: 493 Chicago, Il. USA
D. Bartley
Chicago, Il. USA
We use generally use Technora spliced to double braid for halyards. One of the better places to talk to about sizes is Layline in North Carolina. One of the guys there (Walt) actually has a J/30. Their ph# is 800-542-5463. www.layline.com Another good place may be APS in Annapolis ( www.apsltd.com)
Re: runnng rigging
#3741
10/24/03 10:59 AM
10/24/03 10:59 AM
Posts: 173 Arnold, MD
Joe Ruzzi
Arnold, MD
Have you checked out the article I wrote some time ago about J/30 running and standing rigging ? It lists all the rigging dimensions for a J/30 with some comments about how they are implemented on Mondial.
Re: runnng rigging
#3742
10/24/03 05:41 PM
10/24/03 05:41 PM
Posts: 678 Maryland, USA
Bob Rutsch
Maryland, USA
You can spend more, but we've had great experience and longevity with halyards of 12-strand dyneema/spectra. The old ones had a cover spliced over the winch/clutch area. Just before the NA's we noticed wear near the splices on two and replaced them. Samson Warpspeed (5/16 inch for Jib, 3/8 inch for main) stripped from the mast exit up with luggage tag splices for the shackle. We've never noticed any problem with creep. Higher tech lines than these can be sized so small they won't hold in your clutches or you have to clutch and cleat as we do. Polyester double braid is fine for main because it must be flexible and easy to handle. We use those gold dock lines you see on big power boats for genoa sheets. Don't laugh; they're fat, fuzzy, and cheap. The fatter the better, easy to handle, great on the winch. Only the last three feet get loaded up anyway. Extra long so they can reach the winch, even over the pole. Still usable if you have to cut off a couple feet after a bad wrap.
When it's light we use extra skinny spectra spin sheets. Our primaries are too fat and heavy with big doughnuts and old style snap shackles. I'd like to get something with a wider range, smaller in diameter, still flexible and easy on the hands. Also better, lighter shackles that don't come off when you wipe out during a jibe in heavy air...which leads to shrimping, a torn spinnaker, and loss of four places at the NA's, oh yeah, did that!
48
guests, and 13
