tfrikker, Phil Spletter, kvaschik, mattjenPDX71, loic
918 Registered Users
West Marine Affiliate Link
J/30 Class Affiliate Program
847,041 Dacron Main
128,520 Ananda's Refit
Topics3,746
Posts18,331
Members918
Most Online223
Dec 17th, 2019
Page 4 of 7 1 2 3 4 5 6 7
Re: What Sails are Fast & Last Long? #4138
09/25/06 06:29 PM
09/25/06 06:29 PM
Chicago, Il. USA
D. Bartley Offline
D. Bartley  Offline
Chicago, Il. USA
When was the #2 dropped? As far as I know, you're no longer required to carry it, but that doesn't prevent you from having one. And now it can be kevlar.
The problem with 2s was nobody had a good one, so you'd never really use it. I have a dacron 2, and use it perhaps 2 or 3 times/year on Loch Mich. I suppose it'd be pretty rare on C'Bay or LIS.
Dennis Bartley
Planxty, s/n 23994
hull 205
Re: What Sails are Fast & Last Long? #4139
09/25/06 08:18 PM
09/25/06 08:18 PM
New York, NY, USA
dwl Offline
dwl  Offline
New York, NY, USA
Yeah, I know you can have one, and we were all reminded why they sometimes make sense. Anyone with a clean crisp #2 would have been very happy on Friday. (Well, except for the Zephyr guys, but, hey, they probably could have flown a 175% jib upwind)
- David
Re: What Sails are Fast & Last Long? #4140
09/26/06 09:03 AM
09/26/06 09:03 AM
Marblehead, MA
dbows Offline
dbows  Offline
Marblehead, MA
With the #3 I have always cross sheeted from the block accross the cabin top to the opposite cabin top winch. Works great.
Denis are you talking about cross sheeting the #1 ? I do not know if I would trust my cabin top winches to carry the load with the #1. Is there an alternate arrangement that lets you continue to use the primary winches?
David
#397
Re: What Sails are Fast & Last Long? #4141
09/26/06 10:11 AM
09/26/06 10:11 AM
Maryland, USA
Bob Rutsch Online content
Bob Rutsch  Online Content
Maryland, USA
There was at least one fresh Kevlar #2 up Friday on Pale Rider. Thought I also saw one on Fat City, but could be wrong.
Re: What Sails are Fast & Last Long? #4142
09/26/06 11:05 AM
09/26/06 11:05 AM
Chicago, Il. USA
D. Bartley Offline
D. Bartley  Offline
Chicago, Il. USA
I think what Zephyr did on their own boat was place a pad-eye just behind the jib track, put a turning block on that, then over to the secondary on the opposite side. Perhaps the D ring on primary is used on loaners when there are already the class limit of pad-eyes installed?
Dennis Bartley
Planxty, s/n 23994
hull 205
Re: What Sails are Fast & Last Long? #4143
09/26/06 06:27 PM
09/26/06 06:27 PM
Chicago, Il. USA
D. Bartley Offline
D. Bartley  Offline
Chicago, Il. USA
I should have said Genoa track, not jib... between the track and the primary winch.
Dennis Bartley
Planxty, s/n 23994
hull 205
Re: What Sails are Fast & Last Long? #4144
09/26/06 08:22 PM
09/26/06 08:22 PM
Milford, CT
sjans Offline
sjans  Offline
Milford, CT
We were docked next to team Zephyr,(that's the closest we got) so we had a good look at the boat.
They had a block tied with a regular sail-tie on the primary winches and were using the secondary winches to trim the genoa.
Bob, I wish it was fresh kevlar, but it was a cruising dacron #3.
Re: What Sails are Fast & Last Long? #4145
09/27/06 09:25 PM
09/27/06 09:25 PM
Marblehead, MA
dbows Offline
dbows  Offline
Marblehead, MA
Has anyone ever tried the Lopez blocks like on the J24 for cross-sheeting? I bet you could put them on the very end of the Genoa track nearest the primary winch.
For those who do not know they are a stand up block with a cam cleat that is angled so that the cam trips when the line is sheeted by a winch. So you sheet in by hand and the cam hold until you start trimming with the winch on the windard side.
dbows
#397
Re: What Sails are Fast & Last Long? #4146
09/28/06 11:49 AM
09/28/06 11:49 AM
Chicago, Il. USA
D. Bartley Offline
D. Bartley  Offline
Chicago, Il. USA
One problem that Zephyr had when the turning block was placed farther forward was when you led the sheet from the port side up to the starboard secondary the line would chafe badly on the coach roof. The problem doesn't occur with the starboard sheet because the line is led to the outboard side of the drum (hope that makes sense?).
I suppose one solution would be to reverse the gearing on the starboard secondary so you'd wrap the line counter-clockwise. Z's initial fix was to move the starboard secondary winch aft onto a pedestal (for lack of a better word). The class decided that moving winches about was an illegal modification.
Dennis Bartley
Planxty, s/n 23994
hull 205
Re: What Sails are Fast & Last Long? #4147
09/28/06 06:42 PM
09/28/06 06:42 PM
New Orleans, LA, USA
David Erwin Offline
J/30 Class Co-President
David Erwin  Offline
Dennis, that class ruling was in 1992-1994 time frame I think. We attempted to cover the chafing with a peice of metal. In 2001, the class also ruled against the metal as well. So we simply allowed the chafing.
There are probably several ways to accomplish the same goal. On loaner boats, Zephyr uses a low tech method of tying a block to the primarys with a North Sails sail tie.
The complete goal here is to sail the boat flat when the wind is on. This is harder to accomplish if the #1 is trimmed from the low side.
0 registered members (), 26 guests, and 1 spider.
First cruise
Anchor - type and size
by Pabs. 09/19/20 11:09 AM
Main sail for sale
by Sts. 09/18/20 08:57 PM
What's in the boom for the outhaul?
by Gary Krogman. 09/13/20 07:06 PM
Propane Locker
by Rob Van Name. 09/12/20 05:49 PM
Spinnaker pole for sail
by Sts. 09/11/20 05:32 PM
#1Genoa kevlar for sale
by Sts. 09/11/20 05:09 PM
#1 Genoa
by Sts. 09/11/20 05:00 PM
Spinnacker for sale
by Sts. 09/11/20 04:14 PM
What Transmission Ratio to use with Yanmar 2YM?
by Rob Van Name. 09/11/20 09:21 AM
WTB 2GM Water Pump
by --Ajax--. 09/04/20 12:12 PM
