Re: What Sails are Fast & Last Long?
#4138
09/25/06 06:29 PM
09/25/06 06:29 PM
Posts: 493 Chicago, Il. USA
D. Bartley
Chicago, Il. USA
When was the #2 dropped? As far as I know, you're no longer required to carry it, but that doesn't prevent you from having one. And now it can be kevlar.
The problem with 2s was nobody had a good one, so you'd never really use it. I have a dacron 2, and use it perhaps 2 or 3 times/year on Loch Mich. I suppose it'd be pretty rare on C'Bay or LIS.
#4139
09/25/06 08:18 PM
09/25/06 08:18 PM
Posts: 124 New York, NY, USA
dwl
New York, NY, USA
Yeah, I know you can have one, and we were all reminded why they sometimes make sense. Anyone with a clean crisp #2 would have been very happy on Friday. (Well, except for the Zephyr guys, but, hey, they probably could have flown a 175% jib upwind)
- David
#4140
09/26/06 09:03 AM
09/26/06 09:03 AM
Posts: 649 Marblehead, MA
dbows
Marblehead, MA
With the #3 I have always cross sheeted from the block accross the cabin top to the opposite cabin top winch. Works great.
Denis are you talking about cross sheeting the #1 ? I do not know if I would trust my cabin top winches to carry the load with the #1. Is there an alternate arrangement that lets you continue to use the primary winches?
David #397
#4142
09/26/06 11:05 AM
09/26/06 11:05 AM
D. Bartley
Chicago, Il. USA
I think what Zephyr did on their own boat was place a pad-eye just behind the jib track, put a turning block on that, then over to the secondary on the opposite side. Perhaps the D ring on primary is used on loaners when there are already the class limit of pad-eyes installed?
#4143
09/26/06 06:27 PM
09/26/06 06:27 PM
D. Bartley
Chicago, Il. USA
I should have said Genoa track, not jib... between the track and the primary winch.
#4145
09/27/06 09:25 PM
09/27/06 09:25 PM
dbows
Marblehead, MA
Has anyone ever tried the Lopez blocks like on the J24 for cross-sheeting? I bet you could put them on the very end of the Genoa track nearest the primary winch.
For those who do not know they are a stand up block with a cam cleat that is angled so that the cam trips when the line is sheeted by a winch. So you sheet in by hand and the cam hold until you start trimming with the winch on the windard side.
dbows #397
#4146
09/28/06 11:49 AM
09/28/06 11:49 AM
D. Bartley
Chicago, Il. USA
One problem that Zephyr had when the turning block was placed farther forward was when you led the sheet from the port side up to the starboard secondary the line would chafe badly on the coach roof. The problem doesn't occur with the starboard sheet because the line is led to the outboard side of the drum (hope that makes sense?).
I suppose one solution would be to reverse the gearing on the starboard secondary so you'd wrap the line counter-clockwise. Z's initial fix was to move the starboard secondary winch aft onto a pedestal (for lack of a better word). The class decided that moving winches about was an illegal modification.
44
guests, and 14
