Re: Propeller removal
#4246
11/15/05 02:43 PM
11/15/05 02:43 PM
See: http://www.martec-props.com/install_eliptec.htm The nut is left loosey. If you have any slop at the axle, you will enjoy dramatically improved performance if have have Martec refurbish your prop
guests, and 1
spider. |
