Re: PHRF rating ??????
#452
09/23/08 06:33 PM
09/23/08 06:33 PM
Posts: 649 Marblehead, MA
dbows
Marblehead, MA
Taras -
PHRF-NE Base J/30 handicap is 144.
144 - 3 (J+1 pole) = 141 White sail: 141 + 9 (large fractional) = 150 My Handicap:
144 - 3 (J+1 pole) - 6 (163% Genoa) = 135 White sail: 135 + 9 = 144 David 3397
[This message has been edited by dbows (edited 09-23-2008).]
[Re: D. Bartley]
#7111
03/12/09 10:05 AM
03/12/09 10:05 AM
Cap'n Vic
Newport and Naples
I wonder if we are talking the same things. Here in SWFL we get for Buoy 141 and RLC 138 (RLC random leg course) thats with a 155 I get 6 for a roller furling ... which is supposed to make up for the fact that it isn't a deck sweeper I guess. I get 3 for a UV cover so that gets me up to Buoy 150 RLC 147 And non spinnaker they kick in another 21 and those are Buoy 171, RLC 168 BUT YOU HAVE TO MAX out the size of the genny ... 155 is 0 ... 163 -3 145 adds 3 ... a 148 will get counted as a 155 ... I have found a 145 a bad combination for PHRF... rather go with a first reef main and the 155 as the wind goes up. I had North build my first reef at 15% instead of 20 ... if I remember right just to help on that. v
PHRF-NB Rating Adjustment Spring 2009
[Re: Cap'n Vic]
#7235
04/07/09 08:21 PM
04/07/09 08:21 PM
Posts: 2,669 Portsmouth, RI
Rhapsody #348
The Narragansett Bay J/30 fleet asked PHRF-NB to look at the J/30 OD rating and successfully had it changed. Last year PHRF-NB changed the base head sail rating from 150% to 155% to be more consistent with other PHRF rating bodies. When they adjusted the ratings last year for this new baseline, the J/30s lost one second to all the boats with similar ratings, but there were no changes to those boats. Here is the result of the 2009 rating evaluation. PHRF Spinnaker 138 (was 137 in 2008 and before) PHRF Non-Spinnaker 155 (was 154 in 2008 and before) With this adjustment, J/30s are now the same relative to other boats. I also get a rating for just the #3 for when I enter doublehanded races. That PHRF rating is 150 spinnaker and 173 non-spinnaker (no change from before).
What Are your PHRF Ratings for 2009?
[Re: Rhapsody #348]
#7294
04/21/09 12:03 AM
04/21/09 12:03 AM
Rhapsody #348
I'm collecting data to update the J/30 Class website with 2009 PHRF Rating data to replace the old J/30 PHRF page. For those that have a valid J/30 One Design PHRF certificate, please reply here and include a response in the following format: Rating Body, PHRF Spin, PHRF Non-Spin, J/30 Genoa Size %, Base Headsail Rating % - the Base Headsail Rating is the standard headsail size the rating authority uses (even though J/30 OD is 163%) Examples: PHRF-NB, 138, 155, 163%, 155% PHRF-NE, 135, 144, 163%, 155% Lake Michigan PHRF, 138, 144, 163%, 155% ECSA PHRF 135, 155, 163%, 155% For those racing PHRF in a configuration other than One Design, please provide comments with your rating (e.g. roller furling, 155% headsail, etc.
Re: What Are your PHRF Ratings for 2009?
[Re: Rhapsody #348]
#7297
04/21/09 02:31 PM
04/21/09 02:31 PM
Cap'n Vic
Newport and Naples
http://www.WestFloridaPHRF.orgPHRF Spin Base Buoy 141, RLC 138 155% (163 would be -3) Roller Headstay with cover +9 Vee Jay adjusted Buoy 150, RLC 147 PHRF Non Spn Buoy 171, RLC 168 (they have a magic and mystical way of applying non spin "offsets" in this case they add 21 ... but these offsets appear to follow a somewhat arbitrary formula.)
[Re: Cap'n Vic]
#7299
04/21/09 05:57 PM
04/21/09 05:57 PM
dbows
Marblehead, MA
PHRF NE Base 144 PHRF NE OD 135
LP Adj -6 (>155%) Spin Adj -3 (J+1)
[Re: dbows]
#7300
04/22/09 09:34 AM
04/22/09 09:34 AM
Posts: 83 Waukegan, IL
jhoskins
Waukegan, IL
Lake Michigian PHRF
138 OD 163% 144 155% 147 155% with roller furling credit
John Madcap #358
John Madcap 358
47
guests, and 0
