Re: Actual boat length
#4300
11/17/08 09:21 PM
11/17/08 09:21 PM
Posts: 2,669 Portsmouth, RI
Rhapsody #348
Refer him to the official Class Specs 2008 J/30 Class Specs. There is a section at the end labeled Basic Specifications - LOA 29.92' (29' 11")
#4307
12/02/08 07:38 PM
12/02/08 07:38 PM
JBro
I've dealt with the same issue. The local marina has started to aggressively measure boats and will allow no overhang on a 30' slip. Otherwise, you get bumped up to a 34' slip and at $10+/ft, it adds up! What's fascinating is that there are many J/30s in the marina not subject to measurement because they've been in slips.
This may be obvious but one option is to ship/stow the tiller hard to one side while in the slip. This effectively reduces the length of overhang by the rudder a fair bit.
- Jeff
- Jeff J/30 #426 - Watusi
36
guests, and 1
spider. |
