Re: Halyard replacement
#4514
01/20/04 05:25 PM
01/20/04 05:25 PM
Posts: 127 Chicago, IL, US
rdpierce
Chicago, IL, US
My rope and wire main halyard needs replacement. I don't want to have to deal with wire if possible. I'm also thinking of going with a low-stretch polyester/dacron line. (I've been told that the specta/technora/etc. stretches so little that it will rapidly increase the wear of the dacron main, while low-stretch polyester/dacron will act as a shock absorber.) So I'm wondering:
1. Will a 3/8" all-rope halyard, with the cover on, still fit into the sheaves? I've done eye splices on double-braided rope and found that after the splice, the rope is thicker and doesn't bend as well; will that cause a problem when hoising the main?
2. My existing main halyard had a rope part that looks larger than 3/8", possibly 7/16". Are the rope clutches on a 1981 J/30 compatible with 3/8" line? (I tried it, and the clutch did close and grip the line, but I'm not sure how tightly....)
Thanks, Ryan Pierce, #337
Ryan Pierce, #337
#4519
02/04/04 05:36 AM
02/04/04 05:36 AM
Be carefull, we once had a problem in replacing the wire halyard with rope. The wire made a groove in the sheave and when we replaced the wire, with rope, the new rope halyard locked into the sheave and would not go up. We had to replace both sheaves in the mast head.
36
guests, and 1
spider. |
