Re: How much does a J/30 weigh
#4546
10/05/03 07:45 PM
10/05/03 07:45 PM
the previous owners removed the rope clutches and filled the holes--problem was that the patched holes leaked. One leaked right into the sink(was that planned!)I redrilled them and filled them with marinetex. but the real question is "why is my boat so heavy" maybe I will reweigh this fall and next spring.
#4547
10/05/03 08:35 PM
10/05/03 08:35 PM
My boat was lifted by a crane onto a cradle today. The crane's load cell measured the weight at 7,300 pounds. The accuracy was probably plus/minus a hundred or two pounds so perhaps the boat is actually a touch lighter. Note that she was lifted without a mast/sails/cushions/sheets/eletronics/and all other gear removed. This is a bit surprising because I thought it would have weighed less fully striped out. I've always expected my boat to be on the light side. I don't have floatation marks, but maybe I'll add them for interests sake next season. My big concern with weight was for trailering and it sure looks like a 6,000 and even a 7,000 pound capacity trailer is out of the question.
#4550
12/10/03 02:40 PM
12/10/03 02:40 PM
Clint, Are you interested in selling your J/30 trailer?
You can contact me at dsolutions1@cox.net or 504.382.8469
Thanks
#4551
12/30/03 10:48 AM
12/30/03 10:48 AM
Posts: 12 Larchmont, NY USA
teresa
Larchmont, NY USA
I am building a database of J30 weight. Please let me know if you have weighed yoou boat and include the following information. Hull # Weight Method used to determine weight, i.e., load cell, truck scale, etc. Equipment on board See rule 5.14.4 Sailing Weight Rigged ?? Please let me know if you want the weight kept confidential (Email me direct) Thanks Larry Christy J30 Class Measurer alchristy@comcast.net
guests, and 1
spider. |
