Re: Rudder plates
#4592
08/11/06 12:57 PM
08/11/06 12:57 PM
Posts: 159 grand rapids, mi
311 Temptation
grand rapids, mi
Why not get down inside with a wrench & simply tighten all the bolts on both plates ?
While you are at it, put a dab of goo in the bolt holes for good measure, to seal out the juices.
Re: Rudder plates
#4593
08/11/06 02:43 PM
08/11/06 02:43 PM
Posts: 4 Boston, MA
ty 495
Boston, MA
The others are already tight, the loose one comes directly out. I suppose I should pop the yanmar instrument panel out for a real look at what's behind there. A crumbling mess at the mooring is better than being rudderless halfway around the race course. Thanks. Originally posted by 311: Why not get down inside with a wrench & simply tighten all the bolts on both plates ?
Re: Rudder plates
#4594
08/14/06 01:33 PM
08/14/06 01:33 PM
Posts: 649 Marblehead, MA
dbows
Marblehead, MA
Ty,
If you need a hand let me know.
David #397
34
guests, and 1
spider. |
