March
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
1017 Registered Users
976,298 Dacron Main
162,662 Ananda's Refit
Rudder plates #4591
08/10/06 09:16 AM
08/10/06 09:16 AM
Boston, MA
ty 495 Offline
ty 495  Offline
Boston, MA
I noticed 1 of the 4 bolts in my outboard upper rudder plate (fastened to the transom)has come loose. The other 3 appear to be solid. Does anyone have an idea for a quick fix? Or, has anyone experienced this and think I might have a bigger problem waiting to happen? I am mildly concerned that the natural play with the rudder pins could loosen the other 3 tight bolts by the end of the season. With a dozen races left I'd prefer not to haul at this point. Any ideas would be welcome.
Ty #495
Re: Rudder plates #4592
08/11/06 12:57 PM
08/11/06 12:57 PM
grand rapids, mi
311 Temptation Offline
grand rapids, mi
Why not get down inside with a wrench & simply tighten all the bolts on both plates ?
While you are at it, put a dab of goo in the bolt holes for good measure, to seal out the juices.
Dell Todd
#311 Temptation
Holland MI
Re: Rudder plates #4593
08/11/06 02:43 PM
08/11/06 02:43 PM
Boston, MA
ty 495 Offline
ty 495  Offline
Boston, MA
The others are already tight, the loose one comes directly out. I suppose I should pop the yanmar instrument panel out for a real look at what's behind there. A crumbling mess at the mooring is better than being rudderless halfway around the race course.
Thanks.
Re: Rudder plates #4594
08/14/06 01:33 PM
08/14/06 01:33 PM
Marblehead, MA
dbows Offline
dbows  Offline
Marblehead, MA
Ty,
If you need a hand let me know.
David
#397
Cabin Table Wanted
by B Davis. 01/20/24 11:03 PM
Fuel Fill O Ring
