• Home
  • Class
    • Membership Application
    • Board of Governors
    • History
    • Contact Us!
  • Calendar
  • Fleets
    • Directory
    • Districts
    • Teams
  • Forum
  • Info
    • Official Specifications
    • PHRF Rating
    • J/30 @ J/Boats.com
    • Why Own a J/30?
    • J/30 Drawings and Files
    • Diesel Engine Maintenance
    • Articles of Interest
      • J/30 Rigging Information
      • J/30 Spreader Brackets
      • J/30 Rig Tuning
      • J/30 Crew Assignments
      • Cruising Your Racing J/30
      • J/30 Trailering
      • Building a Parking Sail
      • Barient Winch Information
      • Painting Your J/30
      • Shaft Log Replacement
  • Market
    • For Sale
    • Wanted
    • Equipment Suppliers
    • J/30 Apparel
    • J/30 Online Store
  • Photos
  • Regatta
2012 J/30
North Americans
October 18-21
New Orleans YC
New Orleans YC
2012 J/30 SNE
Regionals
July 21-22
Newport YC
Newport YC
2012 Cedar Point OD
June 2-3
Cedar Point YC
Cedar Point YC
Active Topics
Active Posts
Unanswered Posts
Advanced
You are not logged in. [Log In] J/30 Class Association » Forums » J/30 Forum » The Boat, Sails and Equipment » Stainless steel J/30 parts
May
M Tu W Th F Sa Su
Bob Rude
595 Registered Users
j30news
(Views)Popular Topics
Dacron Main 97922
Northwest one-design 55235
J30.org Web Page 20724
Southern Straits 13273
Forum Stats
595 Members
27 Forums
2619 Topics
Page 2 of 4 < 1 2 3 4 >
Topic Options
#12527 - 10/20/11 10:50 PM Re: Drawing for J/30 Rudder Pintles & Gudgeons [Re: Rob Van Name]
Conundrum Offline
Loc: Oxford, MI
Thanks Bill
I plan on working out the slack in my steering this winter.
The pintle and gudgeon cannot both be 1.000 in. There must be clearance in there. I hope to find it in the pintle, easier to replace.
Do most of the J30s have a little steering slop.Mostly noticed downwind. How have others handled this?
_________________________
Top
#12528 - 10/21/11 08:42 AM Re: Drawing for J/30 Rudder Pintles & Gudgeons [Re: Conundrum]
Cap'n Vic Offline
Loc: Newport and Naples
the clicking is part of the driver steering reflex input process.
in combination with other tactile inputs this provides a deeper "oneness" with the boat.
why would you want to disable this input?
Naples
J24 Bang!
NPT
Top
#12532 - 10/21/11 05:55 PM Re: Drawing for J/30 Rudder Pintles & Gudgeons [Re: Rob Van Name]
NaturalHigh Offline
Clicking? Mine is more like a "clunk". Not so loud when at the helm, but if you are below, it is pretty obvious
Top
#12538 - 10/23/11 06:45 PM Re: Drawing for J/30 Rudder Pintles & Gudgeons [Re: Rob Van Name]
dlabrosse Offline
Loc: Vancouver, BC, Canada
Yeah, mine is pretty sloppy too. I'd love to tighten it up a little. Would really help in light air especially.
Dominique Labrosse
Red Five, #92
Top
#12549 - 10/25/11 12:46 PM Re: Drawing for J/30 Rudder Pintles & Gudgeons [Re: Rob Van Name]
sailon Offline
Loc: Melbourne, FL
Teflon tape or heat shrink tubing before a regatta helps.
Top
#13109 - 02/28/12 09:28 AM Feedback from Rod: Drawing for J/30 Rudder Pintles & Gudgeons [Re: Rhapsody #348]
Rhapsody #348 Online   content
Class Co-President
Loc: Portsmouth, RI
I just spoke to Rod Johnstone. Rod seems to remember the clearance being .005" for the pintle to gudgeon. The pin was made of bronze and the gudgeon stainless so it wouldn't wear steel on steel.
Bill Kneller
Rhapsody J/30 #348
Projects & Documentation
Top
#13114 - 02/28/12 07:51 PM Updated Drawings for J/30 Rudder Pintles & Gudgeons [Re: Rhapsody #348]
Class Co-President
Loc: Portsmouth, RI
Updated Drawings
Thanks to Will Museler who updated the drawings based on feedback from Rod Johnstone.
If you click on the pictures below, you can download a printable pdf file for each drawing.
Rudder Hardware Drawing-Model.pdf [71.09 KBytes] - (29 downloads)
Gudgeon Drawing-Model.pdf [91.65 KBytes] - (37 downloads)
Rudder-Hardware.jpg [83.13 KBytes] - (107 downloads)
Gudgeon.jpg [78.2 KBytes] - (105 downloads)
Bill Kneller
Rhapsody J/30 #348
Top
#13117 - 02/29/12 09:09 AM Re: Updated Drawings for J/30 Rudder Pintles & Gudgeons [Re: Rob Van Name]
Russ Atkinson Offline
Loc: Rockwood, MI, USA
Gents,
I'm unaware of what is on other boats but on Wildcat, if the pintle is bronze it has been plated.
So... with a set of calipers, check the size of the gudgeon hole and mike the pin size. The pin can be re-plated to build up the OD. After plating it can be ground to size. Likewise, the ID of the gudgeons could be filled with weld and re-sized (though I would be concerned about heat distortion on such thin material)
If it were my problem, I'd have the gudgeons cleaned up (oversized by .010 or so) to insure they are round and then re-plate the pins and have them ground .005 under the new gudgeon demension. Most any local machine shop should be able to help here.
You don't have much material to work with on the existing gudgeons. If you are making new, I would suggest making the gudgeons oversized and then bushing the holes with a .500 or 1.000 long bushing to give more surface area and something that can be replaced when necessary.
Top
#13118 - 02/29/12 09:45 AM Re: Updated Drawings for J/30 Rudder Pintles & Gudgeons [Re: Russ Atkinson]
Cap'n Vic Offline
Roger, roger SS. ... don't think they would plate bronze with SS.
I know three boats with nice SS pins. As I remember Bill's boat has a set of nice SS pins ... with stainless locking pins as well.
I'm thinking the only thing bronze that moves, other than parts of the motor ... is the prop.
I'm thinking that somewhere we decided that the easiest way to fabricate new pintles was to cut a piece of 1" prop shaft and use a pin and washer on top and just the pin on the bottom.
Naples
J24 Bang!
NPT
Top
#13119 - 02/29/12 09:52 AM Re: Updated Drawings for J/30 Rudder Pintles & Gudgeons [Re: Rob Van Name]
whitedolphin Offline
Loc: Atlanta, GA, USA
I've got an extra set of stainless pintles if anyone is looking - I think they show normal wear - let me know if interested and I'll get some pictures.
-dan
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  David Erwin
Print Topic
View profile
Send a PM
View homepage
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
Who's Online
0 registered (), 10 Guests and 3 Spiders online.
X48 vs J30
Running the spin halyard
by Rhapsody #348
05/21/12 09:34 PM
by Cap'n Vic
05/21/12 08:54 AM
by Cap'n Vic
05/18/12 08:11 PM
Carbon Spinnaker Poles
by Cap'n Vic
05/18/12 08:05 PM
by JeffSmithNJphoto
05/18/12 07:22 AM
Grease Rudder Pintles?
by JeffSmithNJphoto
05/18/12 07:08 AM
by David Erwin
05/18/12 12:36 AM
by Cap'n Vic
05/17/12 08:21 PM
by Alan Veenstra
05/17/12 10:56 AM
Yanmar 2QM Engine Mounts
by CAN106
05/16/12 04:19 PM
Board Rules · Mark all read
