• Home
  • Class
    • Membership Application
    • Board of Governors
    • History
    • Contact Us!
  • Calendar
  • Fleets
    • Directory
    • Districts
    • Teams
  • Forum
  • Info
    • Official Specifications
    • PHRF Rating
    • J/30 @ J/Boats.com
    • Why Own a J/30?
    • J/30 Drawings and Files
    • Diesel Engine Maintenance
    • Articles of Interest
      • J/30 Rigging Information
      • J/30 Spreader Brackets
      • J/30 Rig Tuning
      • J/30 Crew Assignments
      • Cruising Your Racing J/30
      • J/30 Trailering
      • Building a Parking Sail
      • Barient Winch Information
      • Painting Your J/30
      • Shaft Log Replacement
  • Market
    • For Sale
    • Wanted
    • Equipment Suppliers
    • J/30 Apparel
    • J/30 Online Store
  • Photos
  • Regatta
2012 J/30
North Americans
October 18-21
New Orleans YC
New Orleans YC
2012 J/30 SNE
Regionals
July 21-22
Newport YC
Newport YC
2012 Cedar Point OD
June 2-3
Cedar Point YC
Cedar Point YC
Active Topics
Active Posts
Unanswered Posts
Advanced
You are not logged in. [Log In] J/30 Class Association » Forums » J/30 Forum » Racing Tools and Techniques » Heavy Air Trim/Setup
May
M Tu W Th F Sa Su
Bob Rude
595 Registered Users
j30news
(Views)Popular Topics
Dacron Main 97922
Northwest one-design 55235
J30.org Web Page 20724
Southern Straits 13273
Forum Stats
595 Members
27 Forums
2619 Topics
Page 1 of 2 1 2 >
Topic Options
#467 - 02/06/01 03:31 PM Heavy Air Trim/Setup
Alan Grim Offline
Loc: Lake Stevens, WA, USA
In other recent threads in this forum, it has been suggested that the J30 is weak in light airs and strong in heavy air. I have always had the opposite experience. We have been strong against a variety of boats in light winds (under 10 knots) while having difficulties in heavier winds (over 18 kts). Admittedly, our experience is primarily in lighter winds.
I think I understand the basics for heavy air trim but I must be missing something. We flatten out the main with the outhaul, pull the draft forward with the cunningham, pull the traveller up and let the main twist off with the sheet. We also pull good and hard on the vang and try to vang sheet like the J24s do. The backstay is pulled on good and hard to help flatten the main and the forestay. The genoa lead is moved aft to match the twist in the main.
We also try to carry lots of crew weight to hold the rail down some. But I have a hard time keeping the boat flat (less than 15 degrees).
What other methods are used? Does anybody move the rig forward before leaving the dock when winds are expected to be heavy? We typically change down to the #3 early (~15 kts) to keep the boat flat but I'm concerned that this may slow us down. I know that its recommended to carry the #1 up to about 18 kts but we just get way overpowered.
Any help is appreciated.
Top
#468 - 02/07/01 09:51 AM Re: Heavy Air Trim/Setup
pbattin Offline
Loc: Buffalo, NY
alan we race on lake erie phrf and have wind most of the time in the 0-5 or 15-25 we never get off easy the waves are steep and close. we never use the vang up wind(if you are trying to twist the vang will pull the top batten in and stall the sail)number one is used to 15 true and the number 2 is the smallest we will use,the 2(#3 IF LIGHT CREW AND/OR 25+TRUE) is the most underused sail in the J30 FLEET or so it seemes from the postings.
paul battin
Top
#469 - 02/07/01 12:20 PM Re: Heavy Air Trim/Setup
Mark Offline
Loc: Belleville, IL, USA
I have carried the #1 in 20-25 knots on more than one occasion. We do all the normal stuff and... We crank the rig down hard to 3000# on the uppers and lowers. Our main has a flattening reef and we put it in. The main doesn't fill much and is flat as a barn door. Perhaps the most important thing is to feather the boat into the wind and sail a scalloped course. We trim the #1 to about 8-12 inches from the spreader tip and in the puffs I luff about the foreward 1/3 of the sail. It's touchy luffing just enough to keep her on her feet while maintaining speed, but you get used to it. I try to keep her from going beyond 20 degrees of heel. Note that the water is quite flat here. I grew up on Lake Erie and Carlyle at it's worst is like a calm quiet day on Erie.
This is PHRF fleet racing and we may just manage these conditions better then the rest of the boats we've been with but the boat is almoast amazingly fast compared to our competition in conditions like this. Now if we just always managed tactics and strategy as well as sail trim!!
I should note that we end up in this situation because we do a lot of non-spinnaker racing on short courses. There is no time to change sails; you don't even have time to reef the main. There is a striking speed difference between the #3 and #1 off the wind at 20 - 25 knots true. I think if I owned a #2 that was less than 22 years old I'd use it a lot.
[This message has been edited by Mark (edited 02-07-2001).]
Top
#470 - 02/07/01 01:46 PM Re: Heavy Air Trim/Setup
Bob Rutsch Offline
Loc: Maryland, USA
On Bebop, we change to the #2 at about 20 apparent and the #3 at 24, since our crew is usually only about 1200 lbs. From 18 up, mainsheet is as tight as you can get without hooking the upper batten, outhaul and cunningham on, vang pulled on with the main trimmed. I play the traveler, controlling heel and helm pressure, constantly talking to my skipper, and dropping it any time the helm loads up. We don't vang sheet until dropping the traveler has no effect. But, usually with the traveler all the way down, the main is barely working. I don’t like to feather until we are thinking about a reef and #3 at 30. If you feel slow with the #3 blade, ease it and inch or two, drop the traveler and put the bow down. Strapping the #3 is slow.
Top
#471 - 02/12/01 03:25 PM Re: Heavy Air Trim/Setup
John Colpitts Offline
Loc: Halifax Nova Scotia, Canada
Alan, you don't mention rig set-up. We tighten the rig to about 2000lbs upper and lower, if i think it will be really gusty I may shorten the headstay an inch from max, this seems to allow better control of headstay tension and let's us flatten the entrance of the blade a bit better. (shorten the headstay BEFORE you tighten the shrouds!!!) We often sail with 1200lbs crew, and some of our crew won't hike, so we hurt in the heavy stuff too.
Mark, you must have a later boat with 3/8" shrouds - according to my Loos gauge (and the tuning guide, by the way) the max tension on our 1981 model with the 1/4" shrouds is ~2000lbs. Am I missing something? Most of the local J/29's use the 3000lb range I think, they all have 3/8" rigging.
John in Halifax
Top
#472 - 02/12/01 04:48 PM Re: Heavy Air Trim/Setup
Bob Rutsch Offline
Loc: Maryland, USA
Our usual shroud tension is 39-41 which at the high end if off the chart on the Loos gauge. In a breeze I like to add 2-4 full turns on lowers then uppersto 43-44 (a turn at a time on each side switching back and forth). People have been experimenting with rig tension around here, very loose in the light stuff. We used to shorten the headstay 2-6 turns and will if we think the breeze will hold, but generally we don't see too many days on the Cheaspeake with sustained winds over 20.
Top
#473 - 02/12/01 04:55 PM Re: Heavy Air Trim/Setup
Steve Buzbee Offline
Loc: Highland Park, NJ
How loose is loose (on the Loos)? Was Mousetrap using loose settings in Barrington this summer on the light air days, and if so, how did boat speed/point seem to measure up?
_________________________
Blue Meanie J/30 #485
Top
#474 - 02/12/01 05:29 PM Re: Heavy Air Trim/Setup
Mark Offline
I have 1/4 inch shrouds. I've been tuning them to a J24 tuning guide times 3. The heavy setting is off the scale and extrapolated. I'm not sure it's really 3000 and I don't have the guide in front of me. I looked some Up and it might be 2600 that I shoot for. At the other end in light air I have been putting about 1000 on the uppers and 750 lowers.
I like to sail to boat like a J24 too. No twist, vang sheeting, I drive and manage the main as well (I've always thought of the main as an extension of the rudder anyway)...
Top
#475 - 02/13/01 10:53 AM Re: Heavy Air Trim/Setup
Bob Rutsch Offline
Loc: Maryland, USA
No, Mousetrap wasn't doing anything unusual on Sunday at the NA's when it was extremely light. I didn't do the tune, but I believe the skipper loosened things up, probably to about 38 or so. We struggled, but I think it was picking the wrong side and missing a couple big shifts. Speed wise we were fine compared to boats around such as eventual winner Sea Biscuit. The were just smarter. As to the 'radical' rig tension, you'll have to talk to the North guys. As I understand it, in light air they are use very loose lowers to allow the middle of the sail to fall off to leeward.
Top
#476 - 02/13/01 11:02 AM Re: Heavy Air Trim/Setup
Bob Rutsch Offline
Loc: Maryland, USA
As for Mark trimming his own main, more power to you if you can handle it. I was impressed to see Arbella's skipper trimming his own main in a breeze Friday at Barrington. The skipper can feel the helm load up and react quicker, plus it gets another body out of the back of the boat. But most people can't do both when it blows. Even on Arabella I could see it was making the helm less effective than on Sea Biscuit.
I don't get to drive much, but I find it easier to play the traveler than vang sheet when I'm handling both the tiller and the main.
Top
#477 - 02/13/01 12:46 PM Re: Heavy Air Trim/Setup
Mark Offline
I'm 6'2" 240 pounds. I have no trouble vang sheeting the main in 20+ knots. What I do have trouble with is getting around the marks. I've always liked to use the main in conjunction with the rudder to get the boat around the marks, but with the straight 6:1 purchase on my mainsheet there's just too much sheet. I am going to try a set-up that has both 2:1 and 10:1 and see if things improve. I had straight 3:1 on my J24 and could just spin her around marks!
We do a lot of short course stuff so mark roundings can be critical. We had one race last year W/L twice around that took us all of 19 minutes to complete the course!
Top
#478 - 02/14/01 12:42 PM Re: Heavy Air Trim/Setup
Bob Rutsch Offline
Loc: Maryland, USA
I tested dozens of gross trim/fine tune setups including the Harken Magic block system before settling on a two-line 4:1/4:1 (see page 24 system G of the 2000 Layline Catalog). It uses the existing hexaratchet base, but the double with becket on top is replaced with a low profile triple with becket, ratchet and cam. On the boom I used two of the existing three sheeves for the gross trim, added a small floating double for the fine tune. Use different colored sheets and keep both aft of the traveler during the tacks so they won't get tangled. While the fine tune is very nice, the real advantage is being able to quickly ease or trim downwind with the gross trim. That's the reason I chose 4:1/4:1 over 6:1/2:1 which could be done with the same setup and a single floating block. Be sure to ease the fine tune before dumping the main to duck or round the weather mark or you won't be able to release the gross...email if you want details.
Top
#479 - 02/14/01 01:24 PM Re: Heavy Air Trim/Setup
I think Sea Biscuit has a novel approach to rig tension. They leave the shrouds alone, and adjust the forestay. When it blows, they crank the headstay tighter and that automagically tightens the shrouds. Or at least that's what I was once told. Unfortunately, I don't have any quantitive numbers.
On Lake Michigan, when it blows there's usually a bit of wave associated with it. While we're sometimes able to carry a #1 in 25 kts when it's really flat, we have generally switched to a 2 or 3. The terrible thing about having a decent 2 is you have another choice to make
As to rig tension, we leave the headstay alone and crank on shroud tension. Like Bob Rutsch, I remember loose gauge numbers and not pounds. With 1/4" rigging I put about 45.5 on the uppers, and 44.5-45 on the lowers. With a flattening reef, our main can be really flat with the backstay pulled down to just below the stern rail.
I'm afraid I'm not coordinated enough to handle main trim and steer in those conditions. We keep the main sheeted pretty hard, and the main trimmer is working the traveler. When we're working well, there's quite a bit of conversation between the trimmer and driver.
As to rigging changes, we've moved our backstay adjustment forward and double ended so the helm or main trimmer can adjust it. We also have a fine tune on the main so even my daughter could crank on an extra inch when it's blowing 30.
I think we're one of the faster boats around here upwind in a breeze. Downwind, some good crew work seems to keep us in the hunt.
Top
Page 1 of 2 1 2 >
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  David Erwin
Print Topic
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
Who's Online
0 registered (), 10 Guests and 3 Spiders online.
X48 vs J30
Running the spin halyard
by Rhapsody #348
05/21/12 09:34 PM
by Cap'n Vic
05/21/12 08:54 AM
by Cap'n Vic
05/18/12 08:11 PM
Carbon Spinnaker Poles
by Cap'n Vic
05/18/12 08:05 PM
by JeffSmithNJphoto
05/18/12 07:22 AM
Grease Rudder Pintles?
by JeffSmithNJphoto
05/18/12 07:08 AM
by David Erwin
05/18/12 12:36 AM
by Cap'n Vic
05/17/12 08:21 PM
by Alan Veenstra
05/17/12 10:56 AM
Yanmar 2QM Engine Mounts
by CAN106
05/16/12 04:19 PM
Board Rules · Mark all read
