• Home
  • Class
    • Membership Application
    • Board of Governors
    • History
    • Contact Us!
  • Calendar
  • Fleets
    • Directory
    • Districts
    • Teams
  • Forum
  • Info
    • Official Specifications
    • PHRF Rating
    • J/30 @ J/Boats.com
    • Why Own a J/30?
    • J/30 Drawings and Files
    • Diesel Engine Maintenance
    • Articles of Interest
      • J/30 Rigging Information
      • J/30 Spreader Brackets
      • J/30 Rig Tuning
      • J/30 Crew Assignments
      • Cruising Your Racing J/30
      • J/30 Trailering
      • Building a Parking Sail
      • Barient Winch Information
      • Painting Your J/30
      • Shaft Log Replacement
  • Market
    • For Sale
    • Wanted
    • Equipment Suppliers
    • J/30 Apparel
    • J/30 Online Store
  • Photos
  • Regatta
2012 J/30
North Americans
October 18-21
New Orleans YC
New Orleans YC
2012 J/30 SNE
Regionals
July 21-22
Newport YC
Newport YC
2012 Cedar Point OD
June 2-3
Cedar Point YC
Cedar Point YC
Active Topics
Active Posts
Unanswered Posts
Advanced
You are not logged in. [Log In] J/30 Class Association » Forums » J/30 Forum » The Boat, Sails and Equipment » Engine Problems - Air Leak?
May
M Tu W Th F Sa Su
Bob Rude
595 Registered Users
j30news
(Views)Popular Topics
Dacron Main 97922
Northwest one-design 55235
J30.org Web Page 20724
Southern Straits 13273
Forum Stats
595 Members
27 Forums
2619 Topics
Topic Options
#4708 - 06/21/02 12:47 PM Engine Problems - Air Leak?
Wondering if others have the same or similar problems. We race our J30 (do pretty well), hull number 424. Our problem is that after a heavy air race, or any time when we are in heavy air and choppy seas, meaning really bouncing around big time, our engine chokes out. We are getting air in the system somehow after heavy weather. If we're sailing and go to use the engine, the engine starts then quits in about 10-15 minutes. Or if it is running and we really starts bouncing, it will quit. The only thing that gets us going again is bleeding the engine. We have done all the "right stuff" changed filters, cleaned the fuel, etc. Doesn't help. This does not happen all the time - only in strong wind (25 plus), solid choppy sea, or when we've been racing and had to bury the rail a lot because of weather. I know, drop the traveler, we do, and we're reefed, etc. The issue is that it can be dangerous when we have to rely on the engine in heavy seas in an anchorage.
Anyone else have this problem? We are wondering if somehow the fuel pick up is floating or something in the design system. This does not happen unless heavy weather. It happens even with full fuel tank, clean fuel and clean filters. To get going again takes bleeding the system several times at the fuel pump and at the high pressure fuel lines.
All thoughts, others experiences, graciously solicited. We like the boat and want to keep it, and because we race a lot and use it in heavy weather, we need to find a solution.
Thank you, Greggus Yahr, "C-C-Courage", hull 424, Falmouth, Maine.
Top
#4709 - 06/21/02 02:43 PM Re: Engine Problems - Air Leak?
Joe Ruzzi Offline
Loc: Arnold, MD
We had a similar problem on Mondial. The mechanic said that Yanmar had a problem in the way the fuel return lines were routed. He changed the plumbing so that it returned the unused diesel fuel to a "T" fitting about half-way between the fuel tank and the engine. This cured the problem. It didn't make sense to me at the time ... and still doesn't but it did work.
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  David Erwin
Print Topic
View profile
Send a PM
Add to your Watched Users
View posts
Who's Online
0 registered (), 10 Guests and 3 Spiders online.
X48 vs J30
Running the spin halyard
by Rhapsody #348
05/21/12 09:34 PM
by Cap'n Vic
05/21/12 08:54 AM
by Cap'n Vic
05/18/12 08:11 PM
Carbon Spinnaker Poles
by Cap'n Vic
05/18/12 08:05 PM
by JeffSmithNJphoto
05/18/12 07:22 AM
Grease Rudder Pintles?
by JeffSmithNJphoto
05/18/12 07:08 AM
by David Erwin
05/18/12 12:36 AM
by Cap'n Vic
05/17/12 08:21 PM
by Alan Veenstra
05/17/12 10:56 AM
Yanmar 2QM Engine Mounts
by CAN106
05/16/12 04:19 PM
Board Rules · Mark all read
