Re: Anyone had problems with Tach on 2GM?
#4914
07/25/07 08:09 AM
07/25/07 08:09 AM
Posts: 649 Marblehead, MA
dbows
Marblehead, MA
My usual issue is the contacts on the sending unit usually get fouled. I take a wire brush and some fine sandpaper and give them a little cleaning and that solves the issue.
David #397
#4917
07/27/07 08:45 PM
07/27/07 08:45 PM
Posts: 14 Friday Harbor, WA
Gary
Friday Harbor, WA
Originally posted by dbows: My usual issue is the contacts on the sending unit usually get fouled. I take a wire brush and some fine sandpaper and give them a little cleaning and that solves the issue.
David #397 David: thanks for the advice; it was spot on. Tach is not working like a charm. Gary
51
guests, and 0
