5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30
Austin, Bill, MissMayhem, DIVEBUDZ, OlafKnute
935 Registered Users
876,276 Dacron Main
134,997 Ananda's Refit
Topics3,790
Posts18,475
Members936
Most Online223
Dec 17th, 2019
Page 1 of 3 1 2 3
Annapolis Rigging Spreader Bar Kit #4946
11/21/07 11:38 PM
11/21/07 11:38 PM
Melbourne, FL, USA
Rob Van Name Offline OP
Melbourne, FL, USA
I received my spreader bar kit from Annapolis Rigging today. I will try to post some photos of it. The kit consists of a beefy aluminum thru mast spreader bar, port & starboard mounting plates and a bag of 1/4" pop rivets.
Re: Annapolis Rigging Spreader Bar Kit #4947
11/22/07 07:14 AM
11/22/07 07:14 AM
Apponaug Rhode Island
sonskyn Offline
sonskyn  Offline
Rob, please send me the contact details at Annapolis Rigging. Thank you.
Re: Annapolis Rigging Spreader Bar Kit #4948
11/22/07 07:58 AM
11/22/07 07:58 AM
Koos - you can also contact Cory Butlin locally at Hall Spars (401.253.3964). They did the thru-bar fix on Rhapsody a few years back. See this thread: http://j30.us/ubbthreads/ubbthreads.php/topics/3125/Spreader_thru_bars.htm
Bill
Re: Annapolis Rigging Spreader Bar Kit #4949
11/24/07 07:13 PM
11/24/07 07:13 PM
Melbourne, FL, USA
Melbourne, FL, USA
A photo of the spreader kit can be viewed at http://sailnordicstar.blogspot.com/
Re: Annapolis Rigging Spreader Bar Kit #4950
11/25/07 11:07 PM
11/25/07 11:07 PM
sonskyn Offline
sonskyn  Offline
Rob and Bill thank you both for the information. I am in the process of refurbishing the mast and boom so this is a good time to get it done. Has anyone bought a J/30 running rigging from http://www.cajuntrading.ca/index.htm ?
Re: Annapolis Rigging Spreader Bar Kit #4951
12/04/07 09:28 PM
12/04/07 09:28 PM
Westport CT
Bluejacket Offline
Bluejacket  Offline
Westport CT
Rob
please let me know if the bracket holes of annalpolis kit are in the same place as the original brackeet ones. it would make sense that they are so no new holed have to be drilled in the mast for the bracket (just a slot for the bar)
Also what is the trick with the halyards...how do you keep them on the correct side of the bar when you install it-- and whoch side is that, for or aft?
And, do the old spreaders slide onto the bar neatly?
Re: Annapolis Rigging Spreader Bar Kit #4952
12/06/07 12:55 AM
12/06/07 12:55 AM
Olathe, KS
Trouble Offline
Trouble  Offline
Olathe, KS
I would like to have a sketch of the crossbar and the plates. I have access to a cnc plasma cutter and aluminum and stainless steel metal and would like to see if I can duplicate them. If so I think I could save our J-30 owners some money on these kits. Seems like $400 is alfully hihg for what ive seen on the phioto of these items. If you are willing to send me a scetch of these items let me know.
Re: Annapolis Rigging Spreader Bar Kit #4953
12/06/07 08:54 PM
12/06/07 08:54 PM
Melbourne, FL, USA
Melbourne, FL, USA
I spoke to Jay Herman at Annapolis Rigging today. He confirmed that the holes in the new plates match the holes in the mast from the original spreader brackets. Jay recommended installing the new plates and using them as guides to cut the slots. He also said all the halyards, wires, etc should go aft of the thru bar except the topping lift which can go forward if desired. The bar goes thru from the port side so you would use a wire inserted thru the starboard slot to keep the halyards aft of the thru bar. The original spreaders slide onto the bar and Jay recommends they be through bolted with two 1/4" bolts per spreader. Use of the original spreaders is an advantage I see over the Hall kit.
[This message has been edited by Rob Van Name (edited 12-06-2007).]
Re: Annapolis Rigging Spreader Bar Kit #4954
12/07/07 01:10 PM
12/07/07 01:10 PM
Detroit, MI
RobC222 Offline
RobC222  Offline
Detroit, MI
Is there any attachment of the brackets to the thru-bar once installed, or does it have a "tight fit" to the hole in the brackets? Seems like with a bend in the bar, and close clearance with the bracket hole, its going to be hard to feed the bar through 2 brackets plus the mast wall thickness on both sides?
Comment from someone who has done this?
Re: Annapolis Rigging Spreader Bar Kit #4955
01/01/08 09:42 PM
01/01/08 09:42 PM
Melbourne, FL, USA
Melbourne, FL, USA
I've posted some shots of the spreader thru bar installation at my blog http://sailnordicstar.blogspot.com/. It took about 6 hours to install one bracket with 2 trips to ACE hardware ( drill chuck key went over the side early on )...
[This message has been edited by Rob Van Name (edited 01-01-2008).]
Page 1 of 3 1 2 3
0 registered members (), 24 guests, and 0 spiders.
First cruise
sad endings
by David Erwin. 04/18/21 01:21 AM
Looking to buy a J-30
by MissMayhem. 04/17/21 12:46 PM
Folding prop
by Austin. 04/13/21 05:37 PM
by DIANE. 04/10/21 02:27 PM
J-30 Table - good condition
by DIANE. 04/10/21 02:17 PM
Boat Ideas
by David Erwin. 04/05/21 04:23 PM
Running halyards through sheave box
by D. Bartley. 04/05/21 10:46 AM
Salvaged J/30 for parts in St. Pete, FL
by DIVEBUDZ. 04/04/21 10:49 AM
Annual Fleet Message + Membership Renewal Message
by David Erwin. 04/03/21 09:13 AM
Decktop sheave boxes
by Steve Buzbee. 04/01/21 02:47 PM
