Re: solo sailing
#4964
03/10/01 01:53 PM
03/10/01 01:53 PM
The biggest problem I've had when doing shorthanded (yes, even single handed) sailing is folding the main afterwards. One answer is to use hanks, and simply roll the main. A small change I've seen on some boats that makes that a lot easier is to place a small removable plate over 1/2 of exit on the mainsail track on the mast. This way the slugs can't come out, and it's a (relatively) simple job to roll the main.
Re: solo sailing
#4965
03/10/01 09:46 PM
03/10/01 09:46 PM
I bought my J30 in 1985 primarily for singlehanded racing. There was very little that needed modification. I had the bow pulpit modified with an additional rail about halfway between the deck and the top rail (so that I couldn't fall through it) and had a 1/4-in. stainless crossbar welded inside the front of the top rail so that I could attach halyards to it. To keep headsails on deck I drilled holes through the toe rail so that I could have light line lacing on the lifelines as far back as the second stanchion. About 1 ft diamonds. To securely hold the sails down I attached 3/8-in. shock cord with plastic hooks port and stbd from the bow pulpit through the first stanchion base to the second stanchion base. When lowering a sail, I would make sure the halyard was free to run through the rope clutch and turning blocks, then pull it forward from where it exited the mast so that I could control the halyard while I was on the foredeck. Singlehanding the J30, you reef and change jibs based on autopilot performance. The main thing is to keep the boat balanced so that the autopilot doesn't self destruct trying to maintain course. The boat is hard to sail flat in much wind because there is no crew weight on the rail. There's more, such as schemes for getting aboard from the water, disabling the autopilot from the water, etc, but I think the major issue as far as singlehanding the boat is concerned is changing jibs.
Re: solo sailing
#4966
03/11/01 01:24 AM
03/11/01 01:24 AM
Posts: 13 Pensacola, FL, USA
Tom Eskridge
Pensacola, FL, USA
Jim, I'm looking to do more singlehanding or short-handed sailing on my J30, #469. I've been looking at different autopilots, but could use some advice: What kind to you use?
Tom Eskridge Twister #469
Re: solo sailing
#4967
03/11/01 02:31 AM
03/11/01 02:31 AM
I use an Autohelm ST2000 Plus as my primary unit. My backup is an old Autohelm ST2000 which has proved to be more or less bulletproof, but corrects a little too slowly. Off the wind if the seas aren't confused, the ST2000 Plus steers pretty well. Upwind they both do fine.
Re: solo sailing
#4969
03/13/01 12:19 PM
03/13/01 12:19 PM
I have an ST2000. I have really only used it while motoring. How long can you operate it before having to recharge your battery?
Re: solo sailing
#4970
03/13/01 06:16 PM
03/13/01 06:16 PM
I typically run the engine for about an hour every 12 hours or so when racing and that seems to keep everything up just fine. My experience is that the autopilot uses over 1.0 A on average rather than the 700 mA advertised. Once when I couldn't get the engine to start, I got about 36 hours of autopilot usage out of the two batteries before they were too dead to run it. Of course other loads were there on a rationed basis: running lights, interior lights, windex light, radio, etc. Sort of a how long is a piece of string question.
Re: solo sailing
#4971
03/14/01 04:01 PM
03/14/01 04:01 PM
It was a piece of string question. However, your answer was just what I was looking for.
Thank you
45
guests, and 0
