978,305 Dacron Main
163,315 Ananda's Refit
balsa vs Vermiculite #4990
02/17/08 12:28 PM
02/17/08 12:28 PM
Iowa City IA
Phantom364 Offline OP
Iowa City IA
I pulled the floor in the v-berth and the sandwich material looks like 3/8 balsa. I'm still debating pulling the cabin floor. The post I 've suggest that this is sandwich with vermiculite.
1. Is vemiculite distincntly different than balsa?
2. Since the v-berth area is small, I could use the rest of the balsa sheet(2x4) for the cabin. Rather than order two different materials, is there and problem with using balsa in the cabin floor?
thanks
John
Re: balsa vs Vermiculite #4991
02/17/08 01:37 PM
02/17/08 01:37 PM
There's an old thread where Rich Miller posted some great tips in dissecting hull #294 "Clean Sweep" http://j30.us/ubbthreads/ubbthreads.php/topics/5934/Dewatering_Aft_Bilge_Need_Advi.html
He had some comments on the vermiculite.
His pictures & descriptions are here: http://j30.us/J30%20Rebuild/Inner%20Laminate.html
Rich seemed pretty knowledgeable on this, so you may want to contact him.
Re: balsa vs Vermiculite #4992
02/18/08 09:48 AM
02/18/08 09:48 AM
Rochester, MN
Scott Offline
Scott  Offline
Rochester, MN
The floor itself has 3/8 balsa in the sandwich. I've replaced this myself when the floor became very spongy.
The vermiculite is in spots between the floor and the hull. The floor sits on top of the vermiculite. It looks like its there to support the floor.
Re: balsa vs Vermiculite #4993
02/19/08 11:56 AM
02/19/08 11:56 AM
Iowa City IA
Iowa City IA
Thanks that's what I needed to know. Since we have yet another snow day. I'll remove the floor today. These snow days are eating up good June sailing days
