• Home
  • Class
    • Membership Application
    • Board of Governors
    • History
    • Contact Us!
  • Calendar
  • Fleets
    • Directory
    • Districts
    • Teams
  • Forum
  • Info
    • Official Specifications
    • PHRF Rating
    • J/30 @ J/Boats.com
    • Why Own a J/30?
    • J/30 Drawings and Files
    • Diesel Engine Maintenance
    • Articles of Interest
      • J/30 Rigging Information
      • J/30 Spreader Brackets
      • J/30 Rig Tuning
      • J/30 Crew Assignments
      • Cruising Your Racing J/30
      • J/30 Trailering
      • Building a Parking Sail
      • Barient Winch Information
      • Painting Your J/30
      • Shaft Log Replacement
  • Market
    • For Sale
    • Wanted
    • Equipment Suppliers
    • J/30 Apparel
    • J/30 Online Store
  • Photos
  • Regatta
2012 J/30
North Americans
October 18-21
New Orleans YC
New Orleans YC
2012 J/30 SNE
Regionals
July 21-22
Newport YC
Newport YC
2012 Cedar Point OD
June 2-3
Cedar Point YC
Cedar Point YC
Active Topics
Active Posts
Unanswered Posts
Advanced
You are not logged in. [Log In] J/30 Class Association » Forums » J/30 Forum » The Boat, Sails and Equipment » Cracks In Mast
May
M Tu W Th F Sa Su
Bob Rude
595 Registered Users
j30news
(Views)Popular Topics
Dacron Main 97922
Northwest one-design 55235
J30.org Web Page 20724
Southern Straits 13273
Forum Stats
595 Members
27 Forums
2619 Topics
Topic Options
#5071 - 06/15/02 01:29 AM Cracks In Mast
Trouble Offline
Loc: Olathe, KS
Has anyone ever had repairs made to cracks in a mast? I found a crack on my mast. It is located in the area just above the cabin top. The crack was hidden by hardware, but when I removed the turning blocks and the vang attachment bracked at the bottom of the mast I found a crack that travels about half way around the back of my mast. It travels from one fastener hole to another, than another and to a final fastener hole. Can this be welded? Anyone have any ideas in how to repair?
Top
#5072 - 06/23/02 02:07 AM Re: Cracks In Mast
Trouble Offline
Loc: Olathe, KS
I guess nobody has had the same problem I have - since I haven't recieved any respose from any of you. I have talked to rig-rite about a splice sleeve - they will sell me a section of mast to use as sleeve. Some how it needs to be cut down to fit inside the existing mast.. Not sure how that is to be done. Anyone have any experience with this?
Top
#5073 - 06/23/02 05:37 PM Re: Cracks In Mast
Since the mast is tapered, you should get a section that is cut from an area of the mast small enough to just fit inside the section where the repair is to be made. Aluminum can be welded (TIG) but this would not be recommended for the location of the crack is in an area that could fatigue due to repeatedly varying stress. I suggest riveting the section in place above and below the crack. The interior sleeve will move the location of highest stress, so you should keep an eye on your mast for other cracks in this area during future inspections.
Top
#5074 - 07/22/02 12:03 AM Re: Cracks In Mast
Trouble Offline
Loc: Olathe, KS
An update on my mast crack. I talked to rig-Rite and some other rigging shops about repairing the mast. I found that if you weld the mast you need to have it placed in an oven to re-temper it. I didn't have any place to do this in Kansas City so I ordered a three foot section of mast from Rig-Rite to make a sleeve from. I had to cut this mast section into pieces to get it to nest inside the existing mast. The idea is to get the maximim amount of metal to metal contact. I cut off the sail track extrusion from the three foot secion, and then cut a section from the front of the sleeve section. I ended up with two pieces of aluminum sleeve that nested inside the existing mast from the sail track extrusion at the back of the mast, to about an inch or so from the front center of the existing mast. Becaise the mast crack wasn't straight - I cut a two inch section out of my mast where the crack was so the two sections of mast would butt together nicely. I then used stainless steel pop rivets to fasten these two pieces to the inside of the upper and lower sections of the mast.
This repair wasn't that hard to do. You do need a saws-all to cut the sleeve sections and a good heavy duty rivet setting tool to set the pop rivets. I used about fifty 3/16 inch rivets. I also made a two inch thick block of ipe wood to raise up the existing mast step inside the boat to make up for the removal of two inches of mast. The end result would be no change in rigging.
I'm sure that a new mast might be better - but this repair cost me only about $125 - not $3600 for a new mast (plus shipping)
Top
#5075 - 07/22/02 09:15 PM Re: Cracks In Mast
SCampbell Offline
Loc: Anchorage, AK, USA
When I read the original post, your repair was pretty much what I envisioned. You didn't mention it but the other thing I would have done is to bond it all together with epoxy as it was being assembled. Not only would it help to strengthen the repair, it would help to fill any gaps between the spar and the doublers. Maybe next time I should speak up earlier. Good luck with your spar.
Top
#5076 - 07/23/02 11:48 PM Re: Cracks In Mast
Trouble Offline
Loc: Olathe, KS
I thought of bonding it together with epoxy, but the whole process of riveting it together took about four hours. It was also about 100 degrees outside so it would have been hard to use epoxy in this case - the epoxy would set up way too soon - before I had the rivets all set and that might have kept the pieces from drawing together as I set the rivets.
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  David Erwin
Print Topic
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Who's Online
0 registered (), 10 Guests and 3 Spiders online.
X48 vs J30
Running the spin halyard
by Rhapsody #348
05/21/12 09:34 PM
by Cap'n Vic
05/21/12 08:54 AM
by Cap'n Vic
05/18/12 08:11 PM
Carbon Spinnaker Poles
by Cap'n Vic
05/18/12 08:05 PM
by JeffSmithNJphoto
05/18/12 07:22 AM
Grease Rudder Pintles?
by JeffSmithNJphoto
05/18/12 07:08 AM
by David Erwin
05/18/12 12:36 AM
by Cap'n Vic
05/17/12 08:21 PM
by Alan Veenstra
05/17/12 10:56 AM
Yanmar 2QM Engine Mounts
by CAN106
05/16/12 04:19 PM
Board Rules · Mark all read
