Dead Head
#5089
08/20/04 06:14 PM
08/20/04 06:14 PM
Posts: 127 Chicago, IL, US
rdpierce
Chicago, IL, US
I now have a dead head. It is getting next to no suction and is pumping far more air than water. I'm surmising that the seals and valves need replacement.
It's a 1981 boat, and the head has a label saying Wilcox Crittenden, no model number visible. I called the firm, which was quite unhelpful. They don't have rebuild kits for older heads. Now some of the parts are probably unchanged and they might be able to piece something together for me, but that's assuming I can get them some kind of model number.
Any suggestions here? The head is in otherwise perfectly fine condition, and I'd hate to replace the whole thing if it's a problem as minor as a few valves and seals.
Any help pointing me in the right direction would be greatly appreciated, seeing as my wife is now refusing to go sailing until the situation is fixed. ;-)
Thanks, Ryan Pierce, #337
Ryan Pierce, #337
Re: Dead Head
#5094
08/23/04 10:06 AM
08/23/04 10:06 AM
Posts: 173 Arnold, MD
Joe Ruzzi
Arnold, MD
Ryan, I checked the diagram that Seth posted. It seems identical to the head on Mondial ... and had all the parts that I needed for the rebuild. As a mechanical engineer/tinkerer, one thing I found interesting is the way they got a single pump to do double duty. The pump is double acting -- the 1) upper side of the piston handles the inlet water, sucking it in and pushing it through to add rinse water around the toilet bowl, and 2) the lower side of the piston handles the waste from the bowl, pushing it through the outlet seacock.
Good luck ... rebuilding your head, it's not a job, it's a dooootie!...(sorry, couldn't help it)
Re: Dead Head
#5096
08/24/04 12:16 AM
08/24/04 12:16 AM
just for kicks have you tried head lube or any products to delay the rebuild. this year i used some headzyme for the holding tank and it made my pump work much better,
Re: Dead Head
#5097
08/24/04 02:01 PM
08/24/04 02:01 PM
rdpierce
Chicago, IL, US
This is the second season I've owned the boat. The head barely worked when I launched it the first season. I have absolutely no idea how long it's been since anyone serviced the head.
I don't think I can get away with a kludge. The time has come for me to pay the piper. And I'm hoping that regular applications of HeadLube will prolong another rebuild for a while.
I've ordered a rebuild kit from Wilcox Crittenden for the Headmate. Thanks for pointing out that it is the same model! I'll post a reply when the job is done indicating whether all the parts are compatible.
Ryan Pierce, #337
44
guests, and 14
