• Home
  • Class
    • Membership Application
    • Board of Governors
    • History
    • Contact Us!
  • Calendar
  • Fleets
    • Directory
    • Districts
    • Teams
  • Forum
  • Info
    • Official Specifications
    • PHRF Rating
    • J/30 @ J/Boats.com
    • Why Own a J/30?
    • J/30 Drawings and Files
    • Diesel Engine Maintenance
    • Articles of Interest
      • J/30 Rigging Information
      • J/30 Spreader Brackets
      • J/30 Rig Tuning
      • J/30 Crew Assignments
      • Cruising Your Racing J/30
      • J/30 Trailering
      • Building a Parking Sail
      • Barient Winch Information
      • Painting Your J/30
      • Shaft Log Replacement
  • Market
    • For Sale
    • Wanted
    • Equipment Suppliers
    • J/30 Apparel
    • J/30 Online Store
  • Photos
  • Regatta
2012 J/30
North Americans
October 18-21
New Orleans YC
New Orleans YC
2012 J/30 SNE
Regionals
July 21-22
Newport YC
Newport YC
2012 Cedar Point OD
June 2-3
Cedar Point YC
Cedar Point YC
Active Topics
Active Posts
Unanswered Posts
Advanced
You are not logged in. [Log In] J/30 Class Association » Forums » J/30 Forum » The Boat, Sails and Equipment » Removing engine zincs
May
M Tu W Th F Sa Su
Bob Rude
595 Registered Users
j30news
(Views)Popular Topics
Dacron Main 97922
Northwest one-design 55235
J30.org Web Page 20724
Southern Straits 13273
Forum Stats
595 Members
27 Forums
2619 Topics
Topic Options
#5119 - 04/16/02 11:42 AM Removing engine zincs
Happy Birthday Bob Rude Offline
Loc: RI
When I bought my boat three years ago, I had them install new engine zincs in the block of the Yanmar. Now I'm trying to remove them and replace them with new zincs. I have the Yanmar manual but there's no mention on how to remove the nuts from the engine. They seem to be really oxidized in. Should I heat the bolt heads and then try to remove them with a socket wrench? Or, how about dripping some penetrating oil on them, letting them rest, and then going back with the socket?
Any advice would be much appreciated.
Thanks
Bob Rude
532
"Mmmmm"
Top
#5120 - 04/16/02 09:46 PM Re: Removing engine zincs
On the rear zinc try removing the plate with the 4 bolts to which the zinc is attached. With this out you can either try removing the fitting with the zinc in it or leave it attached to the plate and just unscrew the zinc. You will have to install a new gasket with the plate reinstallation. The side zinc can be loosened with an impact gun or try an impact tool which you strike with a hammer. After it breaks free try a 1/2" drive socket wrench with a pipe for additional leverage. Reinstall zincs with teflon tape to act as seal and anti-seize agent. Good Luck
Top
#5121 - 04/18/02 12:27 AM Re: Removing engine zincs
I just did this, the zinc on the side of the engine was easy, I have changed it the last two years. Last year I was unable to get the back one off. So I tried harder this year. I ground the hex down to 7/8ths and still could not get it off, so I took off the 4 screws and took the whole thing to a machine shop and they got it apart. If you need the Yanmar part numbers or any more info email me at j30381@aol.com. Also the West marine store near me stocks Yanmar pencil zincs and you can make the rubber gasket out of a regular hardware gasket. What you need from Yanmar is the gasket that goes around the whole assembly.
Top
#5122 - 04/28/02 03:02 PM Re: Removing engine zincs
Regarding the use of Teflon tape when installing the new zincs, I think it is better to have direct metal to metal contact. The Teflon tape insulates the zinc fitting from the engine head, eliminating the protection afforded by the zincs.
It's probably better to use a non-insulating thread lubricant.
Top
#5123 - 04/28/02 05:38 PM Re: Removing engine zincs
The use of the teflon tape was a direct recommendation of the Mack Boring rep at the J Boat get together in RI in March. I doubt that one layer of tape would completely insulate the zinc since the meer act of tightening the plug in place would cut through the tape sufficiently to provide electrical conductity. This can be tested with a VOM.
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  David Erwin
Print Topic
View profile
Send a PM
Add to your Watched Users
View posts
Who's Online
0 registered (), 10 Guests and 3 Spiders online.
X48 vs J30
Running the spin halyard
by Rhapsody #348
05/21/12 09:34 PM
by Cap'n Vic
05/21/12 08:54 AM
by Cap'n Vic
05/18/12 08:11 PM
Carbon Spinnaker Poles
by Cap'n Vic
05/18/12 08:05 PM
by JeffSmithNJphoto
05/18/12 07:22 AM
Grease Rudder Pintles?
by JeffSmithNJphoto
05/18/12 07:08 AM
by David Erwin
05/18/12 12:36 AM
by Cap'n Vic
05/17/12 08:21 PM
by Alan Veenstra
05/17/12 10:56 AM
Yanmar 2QM Engine Mounts
by CAN106
05/16/12 04:19 PM
Board Rules · Mark all read
