978,305 Dacron Main
163,315 Ananda's Refit
Plastic Sail track on the mast #5253
11/19/07 08:48 AM
11/19/07 08:48 AM
Essex, UK
I
Ian Pavey Offline OP
I
Essex, UK
I have a J30 about 1978 and need to replace the plastic insert in the mast track. - It takes the bolt rope instead of using sliders and therefore goes the whole length of the mast - does anyone know where I can get this track ?
Hope you can help
Thanks
Ian
Re: Plastic Sail track on the mast #5254
11/23/07 08:13 PM
11/23/07 08:13 PM
New Orleans, LA
Rambunctious Offline
New Orleans, LA
I'm not sure what you're referring to. I do not have a plastic insert, nor have I heard of one that fits inside the luff groove on the mast. I have seen systems like Strong Track, but those are for slides outside of the groove, not for boltropes.
Re: Plastic Sail track on the mast #5255
11/25/07 07:03 AM
11/25/07 07:03 AM
Miami, Florida USA
the redhead Offline
the redhead  Offline
Miami, Florida USA
I can't picture it either. I put slides on my crusing main so I can handle it alone... I have to take the gate block off to run my boltrope up on the racing main...no plastic there at all?
Re: Plastic Sail track on the mast #5256
11/26/07 06:32 AM
11/26/07 06:32 AM
Essex, UK
I
I
Essex, UK
Re: Plastic Sail track on the mast #5257
11/26/07 06:47 AM
11/26/07 06:47 AM
Essex, UK
I
I
Essex, UK
If you give me your email address I can forward some photographs of the part that is required .
Re: Plastic Sail track on the mast #5258
11/26/07 09:15 PM
11/26/07 09:15 PM
New Orleans, LA
New Orleans, LA
The plastic insert Ian is referring to are in the photos below.
Ian, if this were my boat, I would simply remove the insert and use the mast's sail track as is.
