Re: Replacement Parts + Hull Drying
#5471
10/21/04 04:03 PM
10/21/04 04:03 PM
Posts: 127 Chicago, IL, US
rdpierce
Chicago, IL, US
I have heard that the exhaust tube isn't secured very well in the transom. That area is cored, so if water gets in there, it's got access to the balsa core in the transom and the hull, and can cause the type of problem you're describing. The hull was built in two halves and glassed together down the center, so a wet stbd side is consistent with a leaky exhaust.
I've seen other people talk about the same problem in this forum.
Good luck!
Ryan Pierce, #337
#5475
10/28/04 06:48 PM
10/28/04 06:48 PM
rdpierce
Chicago, IL, US
The funny thing about my floorboards are that when they've swelled tight, I can't remove them myself.... But with a second person, both of us pulling up at the same time, it's fairly easy. The issue seems to be that lifting one end up at an angle is a lot harder than lifting the whole thing straight up.
Ryan Pierce, #337
45
guests, and 0
