Re: Dacron Main
#5497
07/18/08 07:01 PM
07/18/08 07:01 PM
JBro
This is a very interesring discussion. I'll throw a few additional thoughts, in no particular order, into the mix. While I'm not necessarily speaking for other owners, this does reflect what I've see out here from out here from my corner of the world (Seattle) as both an owner and active crew for many years: - To get a OD start, no one here really complains about sail material as long as the OD dimensions are adhered to. And, I've see J/30s win with a wide variety of sail technology. One boat I drove did quite well despite a recut main that would be worthy of a photo caption contest on Sailing Anarchy. - It's my opinion that a higher tech sail will provide better performance in a wider range of conditions. It will also hold shape (not necessarily construction...) longer. And, if used properly, it *may* provide a better return on investment over a dacron sail. - While it's entertaining to read, unless you are a sailmaker or CAT 1 with a dacron main, I would strongly argue that on identically configured and sailed boats, a newer technology sail will perform better. - On the other hand, I would also comfortably state that even with the best carbon string sails vs. dacron, if you botch a few tacks/gybes, get a bad start, or miss a shift benefitting a gybeset here or there, the dacron boat will probably win. - I'll likely be in the market for a new suit of sails next year. When I buy, I'll likely buy carbon/aramid because the benefit/cost ratio is simply higher. High-tech materials and construction cost have come way down. Further, since about 60%+ of my racing will be PHRF with pervasive use of advanced sails, it simply makes sense to bring a gun to a gunfight. ;-) - I used to sail a OD dinghy that went from all dacron to 49er style, reinforced mylar sails. The new look/performance potential GREW the fleet because it effectively moved the fleet forward. Sail cost remained the same. So - here's a thought: IF the restriction (and I'm honestly not saying it should be) were removed, it *might* draw more boats out of their slips (or owners away from other classes) to join a dynamic, high bang-for-buck class that gives flexibility to the owner to tweak a little. It's my opinion that high-end sails are faster but not so much so that they would ruin a OD J/30 fleet. You have to sail well (boathandling and tactics) to do well and in my experience, that plays a more significant role in the overall results dynamic. Just my $.02. - Jeff #426
- Jeff J/30 #426 - Watusi
Re: Dacron Main
#5499
07/23/08 10:27 AM
07/23/08 10:27 AM
Posts: 649 Marblehead, MA
dbows
Marblehead, MA
Originally posted by Phil: It seems that the cloth restriction's main purpose is to keep the cost of sailing as a OD Fleet as affordable as possible, with two kids in College and two more enroliing in the next two years I wholly support.
So if that's the intent, what is the difference in price between a Dacron Main and a alternative fabric ? I just had my North sailmaker quote me retail prices on Dacron vs their best 3DL main: Dacron 3k, Carbon ~5300 To me that is a huge difference for a sail that does not last twice as long nor is it twice as fast. Sexy factor is very high though (-: David #397 [This message has been edited by dbows (edited 07-23-2008).] [This message has been edited by dbows (edited 07-23-2008).]
Re: Dacron Main
#5503
07/25/08 01:29 PM
07/25/08 01:29 PM
dbows
Marblehead, MA
Well I know if the class OD did not resrict to Dacron I would not have even considered it.
#397 David
Re: Dacron Main
#5505
07/26/08 08:19 PM
07/26/08 08:19 PM
Posts: 45 Detroit, MI
RobC222
Detroit, MI
Originally posted by dbows: I just had my North sailmaker quote me retail prices on Dacron vs their best 3DL main: Dacron 3k, Carbon ~5300
David #397 AND: Originally posted by Mark Wolf:
I bought Quantum Fusion X three years ago; both Main and a 155% #1. These sails are used every week and the main is left on board. Just last week one of my neighbors asked me old are those sails...3 years old...no way, they look almost brand new. I will say they are in incredible shape as there designers intended. The cost for a Dacron main was $3,000 and the Fusion X was $4,100. I specifically bought Fusion X due to it's ability to hold shape and the projected life of the sail. Don't know about prices above, but my Quantum Fusion X cost $3,688 one month ago. Only a 20% premium over the Dacron. Sounds like a good tradeoff to me. Expect it to hold its shape much longer than the Dacron for a longer EFFECTIVE life. [This message has been edited by RobC222 (edited 07-26-2008).]
48
guests, and 13
