Re: Bottom Painting - Looking for Pointers
#5601
03/09/07 02:46 PM
03/09/07 02:46 PM
Posts: 649 Marblehead, MA
dbows
Marblehead, MA
I had no problems with the gel coat. It was amazing, the boat was perfect, absolute mirror finish gelcoat - just like it came out of the factory.
There is one that will not take off the barrier coat. I will get the numbers for you.
David
#5602
03/16/07 04:51 PM
03/16/07 04:51 PM
Posts: 2,669 Portsmouth, RI
Rhapsody #348
Based on info that David Bows and a friend of his provided, Peel Away 7 is roughly equivalent to the Peel Away Marine Safety Strip (compare the Material Safety Data Sheets). I tried dealing with the local Home Depot and they did not have the 5 gallon buckets, only 1 gallon @ $63.97/gal. They offered to discount it by 10%. I looked on the web and located: Castle Wholesalers, Inc. 3450 Bladensburg Road Brentwood, MD 20722 http://www.castlewholesalers.com They sell it at $44.86/gal plus shipping. 6 gallons shipped from them was $60 less expensive than Home Depot when tax was added. So I'm looking out the window at the sleet coming down and have ordered 6 gallons on line. Hopefully when this arrives, the weather will cooperate and allow me to strip the bottom!
#5609
04/02/07 05:09 PM
04/02/07 05:09 PM
Posts: 127 Chicago, IL, US
rdpierce
Chicago, IL, US
Originally posted by whk:
Did the Interlux guy recommend brush tip after roll? I see recommendations elsewhere for the no-nap foam rollers. I've never used one of them and haven't checked these out yet, so need to look into it.
My yard recommended using the West System yellow foam rollers normally used for epoxy. I've had nothing but good luck with them. Ryan Pierce Tesara, #337
Ryan Pierce, #337
51
guests, and 0
