Re: Prop Rattle
#5687
10/04/06 10:02 PM
10/04/06 10:02 PM
Posts: 649 Marblehead, MA
dbows
Marblehead, MA
When was the last time you had the prop re-conditioned?
David #397
Re: Prop Rattle
#5689
10/05/06 10:29 AM
10/05/06 10:29 AM
Posts: 493 Chicago, Il. USA
D. Bartley
Chicago, Il. USA
Probably need to have the prop re-conditioned. If it's still a Martec, they do that for a reasonable fee.
Re: Prop Rattle
#5691
10/05/06 02:17 PM
10/05/06 02:17 PM
dbows
Marblehead, MA
That is true about the tranny. The way to check the prop is the blades should be no closer than 3/8ths of an inch together at the tip when closed and there should be no sideways movement of the blades.
David #397
47
guests, and 1
spider. |
