977,497 Dacron Main
163,062 Ananda's Refit
#3 size... #5821
12/06/08 08:05 PM
12/06/08 08:05 PM
Miami, Florida USA
the redhead Offline OP
Miami, Florida USA
OK, so I know the class rules show min and max size, but I still can't get my head around the quotes from 2 sailmakers at 98%
I could have sworn my favorite dacron #3 was a 105%.... somebody tell me what they have???? Maybe the dacron was never meant to be "class legal"
Re: #3 size... #5822
12/07/08 01:17 AM
12/07/08 01:17 AM
Rhapsody #348 Online content
Rhapsody #348  Online Content
Check out the following spreadsheet with class sail sizes: J/30 Class Sail Dimensions Use the LP/J ratio for % size
Here are the dimensions on a new #3 as measured when I accepted it from Quantum Sails last spring:
LP 3594mm = 11' 9.5" (spec 3550 - 3658mm)
Luff length 9955mm = 32' 7.9" (spec 9982mm max)
Using J=3505mm (11' 6") results in LP/J as measured 102.5%
LP/J Min and Max % ratios 101.3% to 104.4%
[This message has been edited by Rhapsody #348 (edited 12-07-2008).]
0 registered members (), 38 guests, and 10 spiders.
