Re: Transom work
#5983
05/04/01 10:59 AM
05/04/01 10:59 AM
Posts: 124 New York, NY, USA
dwl
New York, NY, USA
I suppose I'm a class purist. I don't quite see the point of doing these sorts of mods. There's no point in doing it for racing. You'll lose the option to go one design, and if you race PHRF, nobody is going to believe it wasn't a bad rating when you win, and who knows what to think about your rating when you lose. PHRF's a bit of a crapshoot in the best of times, when it comes to ratings, but at least with one designs, there's some hope of keeping skill out of the picture. Custom boats, tho, it is pretty hopeless.
In terms of doing it for cruising, well, sure, I suppose. But, structural mods aren't cheap, and you're putting them into a boat that's 20 years old. You're also going to eliminate a bunch of the resale value of the boat because you'll never sell it to anyone who wants to race.
Another reaction, for what it's worth, is that nothing's going to change the overall profile of the boat. It is a touch underpowered, especially in light air. You may squeeze a little speed out of the boat by tweaking the hull form, but that's not going to make a huge difference in that many conditions.
Your milage may vary, but it seems an odd thing to be looking at.
- David
Re: Transom work
#5985
05/08/01 08:55 AM
05/08/01 08:55 AM
I'm certainly not a class purist since I only race PHRF but I would recommend against the modification described for all the same reasons listed in the other responses. You are looking at an siloated design element of the boat - Johnstone considered the entire hull shape, keel, sail plan, etc. when designing the J30 - modifying your boat would mean finding a like minded individual who belives in "innovation" like yourself. Likely you would find that people would shy away from your modified boat once you attempted a sale... I certainly would. One last BIG issue - I assume you race PHRF since you aren't a "purist." Your local PHRF guys will hammer your rating if you effect such a modification. In my area, it seems to be an annual ritual for PHRF to consider lowering the rating of the J30 - your mod would provide ample opportunity for PHRF...
44
guests, and 14
