Recently got a line that was attached to a transom cleat caught in the prop. Broke the strut right off and bent the shaft. What are my next steps/options. Where can I buy the strut and shaft for a 1981 J30, #361? Tks.
Re: Broken strut and bent shaft#6100 08/19/0805:22 PM08/19/0805:22 PM
