Re: LOOSE MAST SPREADERS
#6351
04/27/05 05:08 PM
04/27/05 05:08 PM
Posts: 50 Rochester, MN
Scott
Rochester, MN
Hi all,
Just found a crack in my mast behind the starboard spreader bracket. It goes through the front 3 rivets and just a little above and below the bracket. I have the compression tube add-on in the mast already.
Anyways, while trying to decide between a new mast and trying to get this one fixed, I called Hall Spars and talked to Cory. He says I Can weld the mast, as long as I put a backing plate behind the crack and the weld touches this backing plate while sealing the crack. Then, rivet the edges of the backing plate. Does this make sense? I want to do it this way (at least until I can get a new one), but then I read and hear that you must retemper the mast, but he says no need to with the plate.
Any suggestions, or anyone with experience that had their mast welded with a backing plate?
I also considered to just put a sleave in it, like discussed above, but worried it won't bend enough there, and just cause more problems above and below the sleave.
Also, would love to just buy a new tube from Rigrite, but they are having their own problems right now....
Thanks for the info...
#6352
05/05/05 05:11 PM
05/05/05 05:11 PM
Hi Scott, I have a J29 and this Winter my rigger found the exact same vertical cracking through the rivet holes of both spreader bases.
I am now in the middle of the very same decision making. And because we share the exact same issue, I would be curious which way you have choosen to go?
Have you had any luck getting through to Rig-Rite?
Charleston Spar purchased Kenyon and is the leading supplier of J24 masts. They have told me that they have the extrusion for the J29 mast section and can supply me with a new mast. You may give them a try.
-Rob
42
guests, and 8
