Elbow Grease Results
#6465
05/04/08 10:20 PM
05/04/08 10:20 PM
Posts: 2,669 Portsmouth, RI
Rhapsody #348
Check out Rhapsody's bottom job while suspended in the sling just before going in the water on 24 April. You can see the reflection on the starboard bow. This is the results of spray painting using a Wagner airless sprayer (Home Depot sale $85), followed by incremental wet sanding with 220, 320, 400, then 600 grit paper. The final finish was burnished with fine bronze wool. The paint is Blue VC Offshore. It picked up the gray tone from wet sanding and will probably revert to blue in the water. My arms are shot now.
Re: Elbow Grease Results
#6469
06/02/08 07:40 PM
06/02/08 07:40 PM
JBro
Bill-
Nice work. Having done a similar job (+templating/fairing keel), it makes a significant difference as you've most likely already experienced. The owner of the J/30 freaked out when pulling back into the slip... the boat just kept going and didn't slow as quickly as it did prior to the burnish job.
Cheers, - Jeff
- Jeff J/30 #426 - Watusi
[Re: JBro]
#9400
04/24/10 02:54 AM
04/24/10 02:54 AM
dlabrosse
OK dumb question. I'm about to do a similar exercise with VC Offshore. One of my unknowns is how much paint to buy. How much paint did you need to do the 3-4 coats recommended?
[Re: Rhapsody #348]
#9402
04/24/10 11:41 AM
04/24/10 11:41 AM
dlabrosse
Thanks for the help. If one is going to wet sand and burninsh, Interlux recommends four coats. Looks like I'll be needing 4 gallons then. By way way it's illegal to spray VC Offshore in Canada. I will need to use foam rollers. Hope this does not impact the quantity required.
[Re: NaturalHigh]
#9404
04/24/10 04:00 PM
04/24/10 04:00 PM
dlabrosse
Scott,
I will likely haul at Mosquito creek. I am putting VC offshore on because that's what's on there already and the conversion process to ablative would be even more painful. Besides I want it smooth and fast :-). In the summer months when growth is really bad I have it dived fairly regularly anyways.
The previous owner templated the keel and rudder. I have the templates in my garage if you are interested.
I will be wet sanding and burnishing the bottom. Any bottom prep help will be appreciated. Waiting to do a deal on instruments before making the final arrangements... looks like Raymarine ST60+. It's going to be an expensive haulout but I might as well get it all done at the same time.
Next haulout will be the prop I think.
guests, and 1
spider. |
