Re: Carbon Fiber Poles
#6685
08/18/04 01:34 PM
08/18/04 01:34 PM
Posts: 678 Maryland, USA
Bob Rutsch
Maryland, USA
Online APS and Layline list 14 foot (or less) x 3" carbon pole with Forespar external trip composite ends for $1040 and $1095; Hall is a bit higher, $1016 for just the tube. APS quotes aluminum 13.5'x 3" with same end fittings for $591. I don't know if a 2.5" pole would be strong enough, but the cost is less, $832 at Layline with the same end fittings. My aluminum pole with cast ends weighs 16 lb (+/- .5lb); 11 lbs for the pole, 5 lbs for the two ends. Composite ends save a total of 3.5 lbs (12 oz each vs. 2.5 lbs each). Layline's supplier quotes the 14 foot 3" pole at 7 lbs ( http://www.forterts.com/ordInf2.html#spin). So a carbon J/30 pole at 12.5 feet with the composite ends and a rope bridle would be about 8 lbs. J/24 allows carbon spin poles, but sets the minimum weight at 6 lbs (2.7 kg) for a 9'6" pole, so their carbon poles contain lead in the middle to meet the minimum. This would defeat the purpose for us. I don't think anyone is going to win a race because they made their pole 8 lbs lighter but it might be easier to handle. Will people will rush out and buy one? I'd probably only consider it if we broke our pole, lost it overboard.
41
guests, and 14
