977,746 Dacron Main
163,145 Ananda's Refit
Pole end triggers prohibited #6719
07/13/04 07:43 PM
07/13/04 07:43 PM
Princeton Junction, NJ
S Hunter Offline OP
S Hunter  Offline OP
Revised rules prohibit triggers (section 5.11.4). Does that apply only to composite ends, or aluminum ends too? (not sure how to interpret).
Re: Pole end triggers prohibited #6720
07/14/04 12:59 PM
07/14/04 12:59 PM
Annapolis, MD US
LChristy Offline
J/30 Class Measurer
LChristy  Offline
J/30 Class Measurer
Annapolis, MD US
Triggers have always been prohibited. This is not a new rule. Triggers are used to lock the jaws open during a gybe and are not permitted in most one design classes.
Larry Christy
J30 Class Measurer
Re: Pole end triggers prohibited #6721
07/14/04 01:00 PM
07/14/04 01:00 PM
Annapolis, MD US
LChristy Offline
J/30 Class Measurer
LChristy  Offline
J/30 Class Measurer
Annapolis, MD US
To further clarify my reply. The type of ends is not important. Triggers that lock the jaws open are not permitted.
Larry
Re: Pole end triggers prohibited #6722
07/14/04 02:31 PM
07/14/04 02:31 PM
S Hunter Offline OP
S Hunter  Offline OP
I'm holding an earlier copy of the class rules that do not include that prohibition, at least not in the spinnaker pole section (I'd be surprised if it was elsewhere but I'll check). So now that it is explicitly prohibited in the pole section, does the class consider it acceptable to tape the triggers open for purposes of sailing at the NA's? Appreciate advice soon - I was going to leave on Saturday.
thx.
Re: Pole end triggers prohibited #6723
07/14/04 02:36 PM
07/14/04 02:36 PM
S Hunter Offline OP
S Hunter  Offline OP
e.g., tape over hose clamps - reasonably permanent "defeat" of the triggers. Sound ok?
Re: Pole end triggers prohibited #6724
07/14/04 03:58 PM
07/14/04 03:58 PM
Annapolis, MD US
LChristy Offline
J/30 Class Measurer
LChristy  Offline
J/30 Class Measurer
Annapolis, MD US
The rules start as follows:
Notice to Owners and Sailmakers
It is impossible to foresee every conceivable innovation which may be thought of in the future and to mention every suggestion that has been ruled illegal in the past. When considering anything in connection with the boat or sails or equipment which is not within established practice in the J/30 Class or is not clearly covered by the plans or specifications, you must assume that it is illegal, and must obtain a ruling from the Chief Measurer before attempting it.
Since triggers were not part of the original equipment they are prohibited. We ( Rules Committee) have ruled on this in the past.
If you can disable them and still use the pole that will be OK.
Larry Christy
J30 Class Measurer
Re: Pole end triggers prohibited #6725
07/14/04 04:12 PM
07/14/04 04:12 PM
Annapolis, MD US
LChristy Offline
J/30 Class Measurer
LChristy  Offline
J/30 Class Measurer
Annapolis, MD US
I am posting this for anyone who does not have access to the latest rules
.2 Length from tip to tip of the pole shall not exceed 3810 mm nor when attached to the fitting at the mast, extend more than 3842 mm from the face of the mast.
.3 Bridle is required and the material is not restricted.
.4 Spinnaker end fittings can be of composite material such as the Forespar "ultra" series. A trigger mechanisms for holding the jaws open is not permitted.
Moderated by  LChristy
0 registered members (), 36 guests, and 1 spider.
